Tip & How-To about Apple iPod touch
How To Change The Song on a iPod Touch Without Having to unlock the iPod
To do this you must go to the screen that says the time and "Slide to unlock"
1. Go to that menu
2. Double tap the home botton (The circle with a square in it).
3. Now you can change the volume and song and pause or play.
Apple iPod touch Logo
I NEED A WRITTEN MANUAL FOR SETTING UP MY CELL PHONE WITH STRAIGHT TALK
try: straighttalk.com for instructions or
call straight talk from another phone
Sep 28, 2016 | Cell Phones
how will i unlock a password on an iphone with knowing the phone number
If you are faces with a password protected iPhone, you can still unlock and access iPhone favorites, address book, dial keypad, and voice mail. This trick is not a high tech technique, but just a simple unlocking steps to do. This simple steps can be done because iPhone has the security flaw. Gizmogo posted this steps like the followings:
Try to slide to unlock, tap emergency call, after that, double tap the home button.
Whoola, you will find yourself in iPhone favorites. From there, you could access other menu like address book, dial keypad, and voice mail.
If you are the owner and wants to avoid this security flaw, you could do the following.
1. In the iPhone home, go to Settings.
2. Click on General.
3. Click on Home Button.
4. Click on either "Home" or "iPod".
By doing this, when someone is doing double tap, he/she will be redirected to the unlock screen (if you choose HOME). Good luck.
Dec 19, 2010 | Apple iPhone 3G
If iphone was stolen but password protected. How many attempts do they have to try to get in before iphone is disabled. Also, if they try to restore via computer and don't have same computer I have, will they be able to get in or will it restore and delete all my private data (text, emails, etc.). Thank you!
This only works if you have the older versio of software installed. This trick is not a high tech technique, but just a simple unlocking steps to do. This simple steps can be done because iPhone a flaw. Try to slide to unlock, tap emergency call, after that, double tap the home button, you will find yourself in iPhone favorites. From there, you could access other menu like address book, dial keypad, and voice mail.
4. Click on either “Home” or “iPod”.
OR TRY THIS
U can get rid of the password by putting the iphone in restore mode. Once in the restore mode, you can connect your iphone to itunes and phone in restore mode menu will pop up. Click ok, and hit restore . This will reset your iphone and all of your contents and the iphone will be back to its original factory settings.
You can put the iphone in restore mode by holding the home and power button at the same time (sometimes it only works if u hold the power button at first and then hold on to home button)
Nov 24, 2009 | Apple iPhone 3G
My ipod touch has a white screen and it wont let me do anything
ok what u should try if it is still doing it is,
1) press the home button and hold it for 5-10 seconds.
2) if 1 doesnt work try restoring it on ur comp.
Feb 26, 2009 | Apple iPod touch
664 people viewed this tip
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
