Tip & How-To about Computers & Internet
Acer Aspire Netbook without external DVD/CD rom How to Load CD
This will work on any model or make of net-book or Laptop enabling you to load CD's or DVD s with software onto your net-book laptop especially good when the CD/DVD drive has stopped working or is non existent, there are a few prerequisites before you can carry out this operation.
1:You must be in a networked environment in your home/workplace
2;One of the networked computers must have a CD/DVD ROM available
3:The computers must have been linked in a home or a small office network
4: Printers and sharing must also be activated in that network
Method is as follows:-
On the Work-group/Home network computer with CD/DVD ROM click on Start then my computer and look for CD/DVD ROM icon.
Right click on the icon then click sharing and security enable sharing and security then restart this workstation , You will then see the shared hand icon underneath this icon representing it is a shared item after restart to confirm it is shared.
On the laptop/net-book look in my network places you will see the CD/DVD ROM available to you now all you need to do is place in the work-group computers CD/DVD ROM the required software disk and there you have your problem solved without the expense of purchasing an external CD ROM
Operate now your Net-book/Laptop with available CD/DVD icon and double click it or right click and explore choice is yours.
Look at following Pictures
I hope this explains how to do it if you have further problems let me know
Should you not have at least the above 4 listed items at the top of the page then this method wont work .I will publish another method soon for those people that have no network and only have a single net-book/Laptop with no CD capability
Computers & Internet Logo
Instructions needed to use a Toshiba USB FDD kit to work.
yeas a device driver is a peice of software. it basicly tells your computer what device you've attached and what it does.. if you know the manufacture and model number you can normally type that in google follwed by driver and will give you a list of sources to download it from... you will never have to pay for a driver as it is free from the manufacturer normally on a cd that comes with the device... if you have windows xp or later windows should automaticly recognise it and set it up for you.. it will then appear in you my computer section as a new drive
Feb 02, 2010 | Toshiba LCD Display for Tecra M2, M2V
i want to install the program for LG portable
I am having this problem too, exactly as you describe, my email is goddreaming@yahoo.com.au please post the answer when it comes.
Jan 11, 2010 | LG GP08NU20 DVD±RW Burner
CD/DVD drive on my Dell 1545 laptop does not work
You can go to control panel, then performance & maintenance, then device manager, then try updating the drivers from here or from microsoft's website, or others. Do make sure that product is enabled and working properly in device manager. If need, reiinstall dvd rom software
Oct 10, 2009 | Computers & Internet
Easy CD & DVD Burning and Windows Vista
You may need to run the setup directly from the CD rather than letting the autorun start and running it from there. Open up "My Computer" and go to the CD drive, right click on it and select "Explore" find the "Setup" file, and right click on that, select "Run as Adminstrator".
Dec 22, 2008 | Roxio Easy CD & DVD Burning
acer 5520 travel mate
Depending on the make/model of your laptop you may have to reload everything from CD. Some manufacturers don't supply CD or DVDs in which case they have an utility which enables you to create your own recovery media. Finaly, some have a "restore" partition which you can access by pressing certain keys on boot.
Which ever option you have on your laptop, take note that it will delete everything from your hard drive.
Not being able to conect to the internet/freezing are also signs of infection/malware, have you run a scan? try downloading Spybot from a 2nd PC, put it on a memory stick and load it onto your laptop. it might help
Aug 30, 2008 | Acer TravelMate 2300 Notebook
239 people viewed this tip
David Payne
David Payne
