Tip & How-To about Cell Phones
How to put higher capacity battery into old Nokia Mobile Phones
As we all want longer stand-by and talking times with our mobile phones and sometimes get problems to get an original battery for our old Nokias, here is a tip for this matter:
Most of the former Nokia mobile phones use the battery with the model type number "BL-4C". There are some models using type "BL-5C". This "5C" model has more capacity and could also be used instead of the "4C" model. The 5C model is slightly fatter than the 4C one.
Using BL-5C needs with some Nokia mobile phone models a little modification (like 6100) while others do not (like 6260) and require a bit harder close of the battery lid. Cutting both edges on the batteries sides to fitting in the battery compartment is easy done. Charging process is not influenced and works accurate.
Cell Phones Logo
My Uniden Power Mac 5.8 GHZ w/ 3 phones have short talk time. If I change batteries, will it make my talk time longer. I kept of changing phones from one room to another when i hear beeping for low batt.
Have they always gas short talk time? If they are AA batteries you can replace with rechargeable NiMH with as high milliamp hours as you can get 2400+ these have much more staying power. They should charge ok but sometimes these can upset the charge unit.
Jan 15, 2013 | Uniden 5.8GHz Cordless Phone
nokia 1600 suddenly battery low when switch on battery full. solution plz
Sometime replacing of battery is right, it is more costly So you better go to mobile tech or you can do this.78bf4b2.jpg
Aug 12, 2010 | Nokia 1600 Cellular Phone
when in standby how long should the battery on a J700 samsung mobile phone last before need to be recharged? Carphone warehouse says 48 hrs normal
Please find below official product information.
Battery Information Battery Life in Stand-by Mode 250 hours Battery Life in Talk Time 3 hours
Hope it helped.
Nov 26, 2009 | Samsung J700 Cellular Phone
New cell phone battery trouble
Dont talk or use mobile phone when the phone is charging its battery and charge your mbbile battery for 10 hrs continusly before intinal use Only Charge your mobile when it shows " LOW BATTERY " Dont over charge your mobile Use the mobile to talk only when the network signal is high else use sms facility to communicate Use only original charger to charge the battery
Oct 22, 2009 | Sony Ericsson TM506 Cell Phone
239 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
