Tip & How-To about Office Equipment & Supplies
Canon mp 240,250,270
Error E05,E13,E16 is an error cartridge and you need to replace the cartridge with a new one original canon,not refill.
I cant print it says I'm out of black link and I just replaced it and it's flashing E 1 6
From http://www.refreshcartridges.co.uk/igloo/clearing-canon-pixma-error-message-e13-e16/
Locate the STOP/RESET/RESUME button on your printer which is represented by a triangle within a circle on the body of your printer and is usually in red, white or black as pictured below. With the reset button located hold it down for at least five seconds and then release it.
Aug 02, 2015 | Canon PIXMA Office Equipment & Supplies
error code 5100
hi
You need to replace cartridges
thats a common problem with canon printers
always cartridges give errors lice e10/e11/e13/e15/e16/e3100
canon is not a good choice fro printer
May 07, 2011 | Canon I900D InkJet Photo Printer
E05
At this error you need to replace the cartridge with a new one original canon,not refill or compatible.
Apr 14, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Hi, my canon pixma mp210 shows error 61 or 16 after refilling black ink... ? thanks!
Dear cappina,
Error code E16 indicates that remaining ink is unknown. It is common problem in refilling the cartridge. To fix this problem you need to deactivate ink level detection function. Follow this procedure: press and hold STOP/RESET button for about 9 seconds or more then release it. Now E16 has disappeared and the printer should work properly. As consequence, ink volume in panel become UNKNOWN. No problem. It will be back to normal condition when you replace the cartridge with new one.
Regards,
Source:
Canon Inkjet Forum
Dec 11, 2008 | Office Equipment & Supplies
e16 error , driving me insane !!!
E16 means that the printer does not know the ink levels. I am unaware of a reset for that.
Jul 30, 2008 | Canon Compatible Toner Cartridge Replace...
390 people viewed this tip
jasbo
jasbo
