Tip & How-To about Computers & Internet
Add multitouch to nearly any laptop
If your laptop has a touchpad made by the Synaptics company, you can install a driver that will enable multitouch gestures like the ones Apple uses. This driver is for HP computers, but Synaptics makes touchpads for nearly every brand, and I have this running on a Dell with no issues. The drivers can be downloaded from this site. Once they are installed, find the Synaptics Pointing Device item in the system tray (near the clock) and open it. Go to the device settings tab, highlight your Synaptics device in the list, and click on settings. All the multitouch options are spread out in the window that opens.
Computers & Internet Logo
how to setup multi gesture
if you have a synaptics touchpad, you can use the universal driver. http://techdigger.wordpress.com/2009/04/02/multitouch-synaptics-trackpad-windows-xp-vista7/
Sep 28, 2011 | Computers & Internet
what is the multi gesture option available on my acer aspire timeline 4820tg and how do i switch it on or off . plz help me regarding this. regards ankit
The 4820TG's multi-gesture touchpad executes two-finger scrolling, pinch-to-zoom and rotate functions very well.The touchpad is a huge improvement from previous Acer touchpads. The touchpad is large and very responsive. The single touchpad button is comfortable to use and gentle to press. Multi-touch gestures and scrolling works well while surfing the Internet. Nevertheless, it is highly recommended to lower the sensitivity for "PalmCheck" in the Synaptics software to enable usage of the keyboard and touchpad at the same time. Enable/Disable and other touchpad settings can be made using Mouse Properties (from contril panel) and Synaptics Tab.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 06, 2010 | Computers & Internet
my touchpad works but not its multi gesture its emachines D730
most touchpad drivers will work on windows 7 but the program which control the functionality of the touchpad "Synaptics" or ALPS" pointing device may not be compatible in win7 this is an issue with most computer manufacturers but not their fault since win7 is a new operating system and possibly in the near future who knows when windows will come with a windows update to make touchpads work in windows having all it's functionality available.
try calling your computers maker and ask if they have work arounds for your touchpad some may have options to make all your touchpads functionality work but some may not try calling them and have them check it for you, they should know better since they are trained for the specifics of your system.^_^
Jun 15, 2010 | eMachines eMD620-5133 Notebook
I can't kill the zoom feature on my Acer Laptop. It is a pain.
Go to Control Panel > Mouse > Device Settings > Settings > Advanced Gestures > Pinch
(or alternatively right-click the Synaptics Pointing Device icon in your taskbar and select Pointing Device Properties)
Untick the box that says 'Enable Pinch'. This will disable the zooming.
Additionally, you might be suffering the same problem as I was which was I had no idea how to use the zoom and that's why I wanted to lock it. Having Google stuck on too-big-to-navigate-properly or too-small-to-read for days at a time prompted me to learn. I've since decided the zoom is useful and I'm keeping the feature enabled.
Here is what Synaptics have to say about the 'pinch' gesture:
The Pinch gesture delivers zooming functionality in many applications. The Pinch gesture can be used to perform the same function as a scroll wheel on standard Windows applications that support CTRL-SCROLL WHEEL zoom functionality.
To perform a pinch gesture, place two fingers on the TouchPad surface. Move them closer together or further apart. To zoom in, place your fingers on the TouchPad surface near to each other and then slide them apart. To zoom out, begin by placing your fingers apart and then moving them closer together.
The best zooming experience results when the finger tips of the two fingers are used for the gesture.
That will hopefully be of assistance if you want to learn how to use the zoom rather than disable it. It took some practice but I can do it now without a problem so can fix windows when I accidentally zoom on them.
Aug 03, 2009 | Acer Aspire One PC Notebook
455 people viewed this tip
David Payne
David Payne
