Tip & How-To about Apple iPhone Smartphone
How to change your iPhones background
It is possible to have custom backgrounds for your iPhone and not just the default ones they provide you with, here is how to do so.
First you must find a background you like, here is a link to a good website for them: (http://iphone-wallpapers.org/) Save your desired background to a new folder and remember where that folder is.
Once you have done this open your iTunes and plug in your iPhone, after it has finished Syncing select it in from the menu on the left. Now at the top of the page select the tab labelled "Photos" and check the box that says "Sync Photos from". Now click the drop down box next to the check box and select "Choose folder..." Find the folder that you saved your new background in and press enter. Once you have done all this re-sync your iPhone and unplug it.
Now unlock your iPhone and go to your "Settings" app and select "Wallpaper" Press the image of the iPhones locked and Home screen states and select "Photo Library" Your desired background should be in here, if not go back and make sure you've done everything correctly. Select your new background and confirm it by pressing "Set" Here you can choose between having it as just the lock screen background, just the Home screen background, or both, select the one that you wish and you are done. Press your home button and you should how have your new background.
Hope this helps someone. :)
Apple iPhone Smartphone Logo
iphone 4s user manual
How to Disable Background Refreshing:
This feature is enabled by default, so to shut it off, open up the Settings app and navigate to General > Background App Refresh
iphone-4s-user-manual-dzg1h3itambadwzebupt1uuj-5-0.jpg iphone-4s-user-manual-dzg1h3itambadwzebupt1uuj-5-2.jpg How to Stop iOS 7 Apps from Refreshing in the Background
Feb 06, 2014 | Cell Phones
my iphone was accidentally placed into large font. Now I cannot enter my passcode as the full key pad is out of view Help
Reset the phone by pressing the power and home key at the same time and holding them until it turns off, then restart. If that don't work you will need to restore the phone in itunes
Dec 02, 2010 | Apple iPhone Smartphone
forgot iphone 3g pin
HI If you are asking for pin contact your service provider , he will give you a default pin . If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider which is specific for each and every mobile number . Donot try PUK code many times or else your sim will be blocked and you will need a new sim.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software.
Oct 22, 2009 | Apple Cell Phones
i want to unlock my iphone can u help pls
it will be because of two two problem, one becos of pin code blocked..Otherwise with securuty code.
If it is becosof pin code blockedin the sense.you can call to your network provider customer service and ask for puk code and puk2 code,... You can use these codes for unlock your mobile...if security code is the problem, you can format the mobile and restore default. Hope this will helps you....
Thank you...
Oct 09, 2009 | Cell Phones
iphone no incoming or outgoing calls possible
Make sure "airplane mode" is set to off
Check your sim card is properly inserted
You should be prompted for the sim pin number when the iphone loads up (if it has one set). If the pin number is not entered the sim card will not register with your provider.
If you open settings, what is next to "carrier" ?
it should state your provider there.
If it doesn't, tap it and see if it will list your carrier, by default the iphone is set to automatic, you may need to manually select your provider.
If none of this works, give a detailed description of what has been tried and any other details you can
Sep 20, 2009 | Apple iPhone Smartphone
1,017 people viewed this tip
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
