Tip & How-To about Motorola Mobility i1 Smartphone
Motorola i1 Hard Reset
Resetting your i1:
  1. From the main home screen, tap menu
  2. Tap Settings, then SD card & phone storage
  3. Tap Master Clear
  4. Tap Reset phone
  5. Enter your password, then tap OK to confirm
  6. Tap Erase everything
If you cannot access the menu or your i1 is locked out then follow the source link for the hard reset at start up.
Source: PhoneGenius - Resetting Motorola i1
Motorola Mobility i1 Smartphone Logo
reset zte maxx
Master reset from settings menu
A master reset restores the original factory settings and may delete your personal data on the internal storage, such as downloads, ringtones, images, apps, contacts, and Visual Voicemail. It does not delete data stored on the SIM card or SD card.
  1. From any Home screen, tap the All apps icon.
  2. Tap Settings.
  3. Scroll to the 'PERSONAL' heading, then tap Backup & reset.
  4. Tap Factory data reset.
  5. Tap Reset phone.
  6. If your phone is password protected, you'll be prompted to enter your Pattern, PIN, or Password.
  7. Tap Erase everything.
Master reset with hardware keys
If the device menus are frozen or unresponsive, you can master reset using hardware keys.
  1. Back up data on the internal memory.
  2. With the device turned off, press and hold the Volume Up and Power buttons until the ZTE logo screen appears, then release.
    Press the Volume down button to highlight wipe data/factory reset.
  3. Press the Power button to select.
  4. Press the Volume down button repeatedly until Yes -- delete all user data is highlighted.
  5. Press the Power button to select.
  6. Wait as the device resets.
Nov 28, 2016 | Tablets & eReaders
how do i do a master reset for a LG GS 390
Try a hard reset (it will clear all data and configuration settings, suggest backup first)
- Select Main Menu from the Home screen Tap Settings
- Scroll to and Select Phone Settings
- Scroll to and Select Reset Settings
- Tap Master Reset
- Tap Yes to confirm
- Enter the device's security code, then tap OK. (The default security code is 0000)
Jun 17, 2011 | LG Cell Phones
i did too many pattern attempts my phone is lock n i dont remember my email and password
Try typing 'null' into the password box.
If didnt worked means try to do a hard reset as follows 1 From the Xperia 10 Home screen, tap the applications bar.
2 Tap Settings > SD card & phone storage > Factory data reset > Reset phone.
Beware by hard resetting you will loose all the data in the phone.
Mar 12, 2011 | Sony Ericsson XPERIA X10 Cell Phone
i can not answer the phone if an unknown person rings
If you have tried a power cycle, and this does not help, you may have only one option left than to do a master reset.
First, try this:
  2. Tap Settings, then Privacy
  3. Tap Factory data reset
  4. Tap Reset phone
  5. Enter your password if required, then tap Erase everything to confirm
If that doesn't work, or if your phone is frozen:
  1. Turn the power off. If your Motorola DEFY is frozen, pull the battery out and reinsert it
  2. Hold the Volume Down button
  3. Press and hold the Power button until the device turns on
  4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
  5. Select Clear Storage by pressing the Volume Down button
  6. Press and release the Power button
  7. Now simply confirm your decision: Volume Up for YES and Volume Downfor NO
Feb 28, 2011 | Motorola Mobility Defy Cell Phone
2,147 people viewed this tip
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
