Tip & How-To about Mozilla Firefox
Speedup Mozilla Firefox HTTP network settings
Use about:config to either edit of toggle these settings, if you need to add any preferences
TRUE/FALSE => BOOLEAN
NUMBER => INTEGER
TEXT => STRING
browser.cache.disk.capacity » 150000
browser.cache.offline.capacity » 20480
browser.download.manager.closeWhenDone » true
browser.search.openintab » true
browser.tabs.loadDivertedInBackground » true
browser.tabs.opentabfor.middleclick » false
browser.urlbar.hideGoButton » true
browser.urlbar.maxRichResults » 5
zoom.maxPercent » 400
content.notify.backoffcount » 5
plugin.expose_full_path » true
ui.submenuDelay » 0
nglayout.initialpaint.delay » 0
content.max.tokenizing.time » 2250000
content.notify.interval » 750000
content.notify.ontimer » true
content.switch.threshold" » 750000
browser.cache.memory.capacity » 65536
network.http.pipelining » true
network.http.proxy.pipelining » true
network.http.max-connections » 40
network.http.max-connections-per-server » 16
network.http.max-persistent-connections-per-server » 16 ( slower DSL =6)
network.http.max-persistent-connections-per-proxy » 16 ( slower DSL =8)
network.http.pipelining.maxrequests » 8 (max possible = 30)
There is an experimental XPI addon called Tweak Network that will take care of the http.pipelining all will be saved in the prefs.js file in your unique profile, its a good idea to make a backup of this before you start, you will find this in a hidden folder in your application data under your documents.
There are the other settings using this add-on's you can also easily go back from Power Settings to Default Settings really easily this way.
Mozilla Firefox Logo
saving the info that i entered in my visual basic in microsoft access.. how to code the save???
check this out
Rst.Open "users", strConnect, , , adCmdTable With Rst .AddNew .Fields("username") = txtname.Text .Fields("User_Password") = txtpws.Text .Fields("Access_Type") = cmbUserTypes.Text .Fields("Date_Created") = Now .Update End With Rst.Close
'#### connection to databas
Public connConnection As New ADODB.Connection Public rsRecordSet As New ADODB.Recordset Public rsRecordSet1 As New ADODB.Recordset Public Rst As New ADODB.Recordset Public Rst1 As New ADODB.Recordset Public Rst2 As New ADODB.Recordset Public Rst3 As New ADODB.Recordset Public strConnect As String Public ConnectionOk As Boolean
Public Sub ConnectionMOd() Dim strProvider As String Dim strDataSource As String Dim strDataBaseName As String Dim i As Integer On Error GoTo ErrorTimer strProvider = "provider=Microsoft.Jet.OLEDB.4.0;" strDataSource = App.path ' strDataBaseName = "Z:\database.mdb" ' strDataSource = App.Path strDataBaseName = "\database.mdb" strDataSource = "Data Source= " & strDataSource & strDataBaseName strConnect = strProvider & strDataSource
Set connConnection = New ADODB.Connection connConnection.CursorLocation = adUseClient connConnection.Open strConnect
Set Rst = New ADODB.Recordset Rst.CursorType = adOpenStatic Rst.CursorLocation = adUseClient Rst.LockType = adLockOptimistic ' adLockOptimistic
Set Rst1 = New ADODB.Recordset Rst1.CursorType = adOpenStatic Rst1.CursorLocation = adUseClient Rst1.LockType = adLockOptimistic
Set Rst2 = New ADODB.Recordset Rst2.CursorType = adOpenStatic Rst2.CursorLocation = adUseClient Rst2.LockType = adLockOptimistic Set Rst3 = New ADODB.Recordset Rst3.CursorType = adOpenStatic Rst3.CursorLocation = adUseClient Rst3.LockType = adLockOptimistic ConnectionOk = True Exit Sub ErrorTimer: MsgBox "Error Connecting To DataBase Please Check Network path", vbCritical, "Connection Error" End End Sub
Jan 08, 2010 | Microsoft Visual Basic Enterprise Edition...
to form a jumbled words
Using VB as an example
Dim intLength as Integer
Dim y as Integer
Dim arrOut( ) as String
Dim TempLetter as String
intLength=len(text1.text)
ReDim arrOut(intLength)
Randomize
dim boolDone as boolean ' flag to track unfilled positions
Write a loop that gets each letter from text1, then choose a random number from 1 to intLength
Get the existing letter, then put it into a different position in the arrOut, based on the random number. If something is in that position, try again:
for y=1 to intLength
tempLetter = mid(text1.text,y,1)
boolDone=false
do while boolDone=false
r =CInt(Int((y * Rnd()) + 1)) 'Get random # from 1 to length
if arrOut(r) ="" then 'see if spot has been used
arrOut(r) = tempLetter
boolDone = true
end if
loop
next 'get next letter in text1
text2.text=join(arrOut,"") ' concatenate arrOut, no delimiter.
Hope that helps.
Jul 16, 2008 | Computers & Internet
981 people viewed this tip
Top Mozilla Computers & Internet Experts
Lesley Cameron
Lesley Cameron
k24674
Are you a Mozilla Computer and Internet Expert? Answer questions, earn points and help others
