Tip & How-To about Computers & Internet
How To Install East Asian Language Support In XP Without XP CD
  1. First, check to see if you have the i386 folder on your hard drive. This folder will have the East Asian Language Support files that you need to install. The i386 folder can be found here: C:\WINDOWS\Driver Cache\i386 or here: C:\i386
  2. If you cannot find the i386 folder, you will need to obtain a copy of the Windows XP CD and copy the i386 folder to a USB thumb drive.
  3. Click on the Start menu, open Control Panel, then open Regional and Language Options.
  4. Select the Languages tab and under the Supplemental language support frame, check the the box next to "install support for East Asian languages".
  5. Click on Ok or Apply, then you'll receive a dialog box which says that "The following file ' - ' is missing.." and it also allows you to specify a directory where it should be found. Click on Browse and select the "I386" folder on your hard drive or thumb drive.
  6. After the files are installed, you must restart your computer.
Computers & Internet Logo
while installing xp sp3. Error message: file missing check i333
Are you sure i333 is not actually i386? The i386 folder contains all the files Windows uses to install XP. If you have XP installed already and it is asking for the i386 folder, it wants you to put the original Windows XP folder into your CD drive. If you are attempting to install Windows XP with SP3, there is something wrong with your CD. To avoid this problem in the past you can do this:
Copy Windows XP Installation Files to Local Hard Disk SourcePath Raymond CC
Feb 07, 2017 | Computers & Internet
hi i want to install the chinese,japanese and korean language!! but i dont have a xp cd... what should i do??
  1. Download the files needed to install the East Asian Languages here: http://www.4shared.com/file/HZ2CQc0I/east_asian_language.html
  2. Extract the I386 folder from the Zip file to a folder on your hard drive. Remember the location of this folder.
  5. Click on Ok or Apply, then you'll receive a dialog box which says that "The following file ' - ' is missing.." and it also allows you to specify a directory where it should be found. Click on Browse and select the "I386" folder you extracted from the downloaded Zip file.
Feb 26, 2011 | Computers & Internet
unable input krean language by keyboard
Go to Control Panel, select Classic View on the left frame. Point and click the Regional Language Option. Click the languages Tab. Put a check mark in the box Install Files for East Asian Languages. Click OK to dismiss the warning. Press OK to quit set up, or Apply if you have to change other options.
Hope it helps.
Oct 11, 2009 | Microsoft Windows XP Professional
windows does not see full size of new Hard drive
Is your disk correctly partitioned?
  1. Right-click My Computer.
  2. Click Manage.
  3. Click Disk Management.
Find your newly installed disk and see if there is any unpartitioned space on it. If there is, just create a new partition, or delete the previous one so you can create the partition which will consume full size of the disk.
Jan 15, 2009 | Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334...
Install Xp From Dos
If XP will not install from the CD or if you have a new drive with no operating system onit yet try these:
Install Windows XP from the hard drive with Windows 98 already installed:
Boot Windows 98
Insert the XP CD into your CD reader
Explore Windows XP through My Computer
Copy i386 folder to C:\
Go into C:\i386 folder and double click on winnt32.exe to launch the setup from the hard drive
Install Windows XP from DOS (ie. no OS on a new hard drive):
Boot with a Windows 98 Start Up disk
Insert the Windows 98 CD into the CD reader
Run smartdrv.exe from the Win98 directory on the windows 98 CD (file caching)
Type cd.. to back up to the root directory
Insert Windows XP CD into the CD reader
Copy the i386 folder to C:\
Go into C:\i386 folder on C: and type winnt.exe to launch the setup from the hard drive.
Oct 20, 2008 | Computers & Internet
3,268 people viewed this tip
David Payne
David Payne
