Tip & How-To about Computers & Internet
Calibrate your screen on windows 7
The colors you see on your screen may vary depending on your monitor, graphics card settings, lighting and much more, but most people use the same standard Windows color profile. And that means a digital photo that you think sounds good can be very bad for everyone. Fortunately, Windows 7 is now a color screen Calibration Wizard, which allows you to properly configure your brightness, contrast and color settings, and ClearType tuner to ensure the text is clear and unambiguous. Click Start, type DCCW and press Enter to give him a chance.
Computers & Internet Logo
screen has shrunk
Click start control panel display desktop you can select a different desktop from the drop down list or a browse button where you can select different pictures this may vary depending on your operating system also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal , larger or custom settings
Always click APPLY after making any changes windows 7 Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization. Click Window Color and Appearance. Under Window Color and Appearance, click the color you want, and then click OK. Note If you see the Appearance Settings dialog box instead of the Window Color and Appearance window, the theme might not be set to Windows Vista, the color scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero. Hope this helps.
Jan 07, 2013 | E-Machines eMachines Desktop PC
no signal to monitor
Check ALL cables, connections, try another monitor/cable. You didn't provide the Model of eMachine? Does it have a PCI Graphics Card? Reseat Card.
Jan 05, 2013 | E-Machines eMachines Desktop PC
I installed my graphics card and no display comes up for either monitor. i am trying to setup dual monitors on my computer. When I try to install while my computer is on with one monitor it freezes my mouse. thanks Help!!!
click start control panel display change display settings adjust resolution this may vary depending on your operating system you should a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes
or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes
hope this helps
May 15, 2011 | EliteGroup ECS N6200A-512DZ-H GeForce...
i have installed XFX GeForce 6200TC 128 Mb card and drivers from the supplied driver disc that came with it. i cannot get it to display dual monitors when i go to windows display settings! can u assist please
click start control panel display change display settings adjust resolution this may vary depending on your operating system you should a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes hope this helps
Apr 21, 2011 | XFX GeForce 6200TC Graphic Card
how can i increase graphic card quality
From your "Display Properties" set the "Screen resolution & color quality" to the maximium settings". This will depend on your hardware eg. monitor & graphic card if it can support the maximiun settings!!!
Jan 02, 2011 | Computers & Internet
270 people viewed this tip
David Payne
David Payne
