Tip & How-To about Cell Phones
How to removed your iPhone password?
here is a patch that can remove your iPhone Password.
Download the patch from link below and extract it on your PC, Connect your iPhone with USB to your PC and make sure your iPhone is AFC2 support. (If your iPhone is Jailbroken with Redwn0w so dont care about AFC2)
Then open the iPhone Password Remover folder and just double click on M.H.M.bat !
a Dos windows will apear. after exiting the window restart your iPhone.
Now your iPhone is Passwordless.
This patch is already tested on iPhones: 3GS - 3G -2G OS 3.x and works 100%
Note: your iPhones must be jailbroken and I repeat again that your iPhone must be AFC2 Support.
download this software :http://www.megaupload.com/?d=1HQD5VGV
i hope it will help you ,thanks for viewing..
Cell Phones Logo
IPhone 3G passcode forgotten? anyways?
You can unlock your forgotten phone password by downloading this free software,no need going to apple shop and paying the service.
IPHONE PASSWORD REMOVER
Be sure you have a good working USB cable
Here's the instruction
* download the link above
* locate the file (usually on download folder) and extract the file
* run the program,instruction is already given on screen so you don't have to worry on the procedure.
* reboot your phone
* DONE
Hope this solution helps...Thank you for visiting Fixya...
Aug 18, 2011 | Apple iPhone 3G
I bought a second hand iphone 3g now asking password, what can i do now?
* reboot your phone
* DONE
Aug 04, 2011 | Apple iPhone 3G
how can you reset a forgotten password on the iphone a1203 phone
If you have synced your iPhone with iTunes before you forget your iPhone password, you can reset your iPhone by using iTunes without losing data. Through iTunes, you can restore your iPhone from the last backup and remove the passcode from your locked iPhone while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPhone Passcode with Recovery Mode section below. The following steps will show you how to reset iPhone password with iTunes.
  1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
  2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
  3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by in the Summary window.
  4. In the Summary window, you can see the option "Restore iPhone". Click it and follow prompts to choose the latest iTunes backup to restore your iPhone.
After the restoration process is complete, your passcode will be erased and all your data will be restored from your backup. You will now be able to access your iPhone without any passcode. And you can set your new password on iPhone.
reset-oxaxc0rwhkhzilrwacqreyis-1-0.jpg How to Reset Password on iPhone
Jul 23, 2011 | Apple iPhone Smartphone
my fingerprint reader, USB ports don't work
Hi montitire,
It is required to install the USB Registry Patch to fix the issue. You can download the USB Registry Patch from the below link.
http://s02.download.sony.com/US/pc/SOAOTH-00000055-US.EXE
Hope this helps.
Please let me know if you have any questions or require any further assistance.
Thank you for using FixYa.
Dec 15, 2010 | Sony Computers & Internet
forgot my iphone 3gs 4.0 passcode so i need a default password or a way to get in to my iphone without losing any info, music, apps, etc.
You may try this one as long as your iPhone was jailbroken and must have AFC2 Support(Jailbroken with Redwn0w)
  1. Download the patch from this link: http://www.multiupload.com/038AIZXLS6
  2. Extract it on your PC and connect your iPhone with USB to your PC and make sure your iPhone is AFC2 support. (If your iPhone is Jailbroken with Redwn0w so dont care about AFC2)
  3. Open the iPhone Password Remover folder and just double click on M.H.M.bat !
  4. Dos windows will apear. after exiting the window restart your iPhone. Now your iPhone should be Passwordless.
Nov 24, 2010 | Apple iPhone 3G
216 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
