Tip & How-To about Computers & Internet
How to Convert PDF to Word?
Want to edit PDF files? Tenorshare PDF converter helps you convert PDF to Word that can be editable as you like. It not only supports .doc output format, but .rtf as well. Only three steps, you can synonymous convert PDF files to Word documents with format 100% retained.
Step 1: Import PDF files
Download Tenorshare PDF Converter and install it on your PC. Run the program, you can see the following interface. Select "Convert from PDF", Click "Add Files" button to add PDF files you want to convert. Tenorshare PDF Converter allows you to add unlimited files one time for conversion.
NOTE : If you want to know more about conversion settings parameters, please click "Settings" to review. You can set format, language, etc. there.
Step 2: Specify output options and folder
You can customize all pages or any one as you like to convert. And there are two output formats for you to choose. Then click "Browse" to locate your output folder for your destination files.
Note : To customize pages to be converted, use commas (,) and dash (-) only between page numbers. For example, enter 22, 12-15 means converting the 22th page, page 12 to 15.
Step 3: Convert PDF files with one click
Click "Convert" button to start conversion. After successfully completed, the finish dialogue window will appear. Click "Open File" button to view the converted file or click "Close" button to close the screen.
Computers & Internet Logo
How do you erase text from a pdf file?
Chances are you're using Acrobat Reader to read the PDF (portable document format) file.
You need Acrobat "Writer" (aka Distiller) to actually make changes to a PDF file, as the reader can only read the image file itself.
Jun 19, 2010 | ScanSoft PDF Converter Professional...
248 people viewed this tip
David Payne
David Payne
