Tip & How-To about Computers & Internet
How To Tip #1: Disabling your Startup Items
Is your computer reacting slowly when it starts up and shuts down? The cause of this is likely due to the fact that many people have an enormous amount of programs that launch when Windows starts up. Hence when you boot into the Operating System, Windows wants to load each program while you just want to do something else.
The same goes when trying to shut down your computer. Windows needs to close all open programs and services in order to shut down. The less you have running, the quicker it is to start up and shut down. Additionally, you may also notice a sharp increase in your computer's performance since it won't be using as much of the computer's resources with all those background processes running.
If you have a ton of programs that are loading during startup, it's very easy to disable these. This won't uninstall that program, it just won't start at the same time as Windows. It will still be on your hard drive and ready to work when you want to open it.
To stop these programs from starting up with Windows, simply click on Start, type in MSCONFIG, then hit Enter. Remove the check mark next to Load Startup Items and then reboot. That's all there is to it.
Computers & Internet Logo
COMPUTER CRASHING
Several solutions can be implemented:
1. If you have a laptop then use an external dual fan, which you place right under the laptop to correct it's shut down due to temperature rise.
2. If your computer crushes due to Google Chrome performance you should re-install Chrome. Try to any other Internet browser to see if your computer isn't crushing any longer to make sure that it is in fact Chrome, which causes the crush.
Nov 01, 2013 | Google Chrome
push power button and the power light turns amber and lights up then shuts off. the light in back of the computer is light green and it starts to turn on then dies
The fact that ity is trying to start and shuts off after ..it seams that it is the CPU fan to blame ...If the fan fails to start the CPU will turn the computer down instantly due to the temperature limit ..(in 1 or 2 sec ) ..
so ...open it up ..and see if the fan is spinning ...on start ..and if it is not ...check the connection with the board or replace it ..
(by the way ..this may also be a CPU failure ..and need another one ) ..
Aug 31, 2011 | Dell Inspiron 518 Desktop Computer
The ice at the bottom of the bin for the automatic ice maker melts then freezes into a solid block. Is there a fix for this?
Good day,
If the machine both the freezer and fresh food section work totally normal, and the machine turns off and on as it normally has, then the problem usually lies with the water valve in the bottom back of the machine.
The ice maker, when it fills is designed to fill for a 7 second period of time. Many times, when the ice maker tells the valve to shut off, the valve due to wear, reacts slowly, and allows water to overflow the well of the ice maker, causing this problem. Very common problem.
Apr 08, 2010 | Frigidaire FRT18IS6CW Top Freezer...
My hp pavilion a800n's fan won't turn off
It is possible that your computer is simply overheating causing it to slow down. There are a few ways to check this. Enter the BIOS and go to the hardware monitor, what temperatures does the computer read both for the CPU and the Motherboard? Another option is to install and run a program called HWmonitor that can be found here. Report back when you can.
Mar 18, 2009 | HP Pavilion a800n (PP163AA) PC Desktop
145 people viewed this tip
David Payne
David Payne
