Tip & How-To about Computers & Internet
Gvision monitors virus
Blue screen after install
driver has virus
Computers & Internet Logo
blue screen compaq presario windows xp sp2 cq40
Did you just install a new program or a piece of hardware, update a driver, install an update, etc.? If so, there's a very good chance that the change you made caused the BSOD:
Startup using Last Known Good Configuration to undo recent registry and driver changes.
Use System Restore to undo recent system changes.
Roll Back device driver to version prior to your driver update.
Scan your computer for viruses. Some viruses can cause a Blue Screen of Death, especially ones that infect the master boot record (MBR) or boot sector.
Update drivers for your hardware. Most Blue Screens of Death are hardware or driver related so updated drivers could fix the cause of the STOP error.
Return hardware settings to default in Device Manager. Unless you have a specific reason to do so,the system resources that an individual piece of hardware is configured to use in Device Manager should be set to default. Non-default hardware settings have been known to cause a Blue Screen of Death.
Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including BSODs.
If this doesn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of blue screen
Oct 10, 2013 | Compaq Presario Notebook
stimy computer has the blue screen of death.it will just come on with a black screen and then a blue screen stays on for a second return back to the same problem the red light just stays on.it is a virus what can i do .can i connect my computer to downlod a anti virus.
It's either a virus or a driver problem (most likely a virus). The best solution is to get a external usb cd rom drive, and install a fresh copy of windows back onto the system to ensure no issues.
Jun 15, 2011 | HP Mini 1010NR Notebook
I have an acer that will go to a blue screen after I type in the password then it restarts itself over again the same thing!
Blue screen errors, or blue screen of death (BSOD) errors, are the most severe errors Windows can encounter. Since Windows can not recover from this kernel level error, a blue screen is displayed with the error details. The error details contain a STOP error code, which indicates the type of error.
There are a lot of possible causes for blue screen errors, but most of them relate to the computer hardware. The cause of a BSOD error can be a temperature problem, a timing error, a resource conflict, hardware failure, a corrupt registry, a virus or simply a device incompatibility or driver error.
How to analyze blue screen errors
The first thing to do to analyze a blue screen error is to check the meaning of the STOP error code. You need to stop Windows from rebooting when a STOP error is encountered. Once the blue screen of death is shown, you can check the meaning of the STOP error code. Together with the filename of the driver or module, this will give an indication of the error cause.
Another option to analyze the cause of the blue screen error is to look at the Windows system event log or to debug the memory dump (minidump) that Windows created when the error occurred. The event log can be viewed using the event viewer. Right-click Computer in the Start menu, and then select Manage. In the Computer Management window select Event Viewer. The information in the event log can be of great help to isolate the cause of the blue screen error.
Reading the minidump requires a bit more technical knowledge, but Microsoft has tools to read the minidump.
The most common cause of blue screen errors
In reality, the most common cause of blue screen errors is a device driver problem. Outdated, incorrect or corrupt drivers can cause the system to encounter a STOP error, resulting in the BSOD.
So the easiest way to try and fix a blue screen error is to reinstall and update your system's device drivers. This will ensure that all driver bugs are fixed and that all hardware has the correct driver.
If you know which device caused the error, you can update or reinstall that driver first. The file name in the blue screen of death can help identify the driver. Look for a file with the .SYS extension and search for that file name.
If you do not have the drivers for all devices, or are not comfortable updating your PC's drivers manually, you can use a driver update tool to find, download and update all device drivers for you. Such tools will accurately identify your computer hardware, including any device causing an error, and automatically install the latest drivers for it.
In most cases updating or reinstalling drivers will solve your blue screen errors.
Other causes of blue screen errors
However, if updating device drivers does not fix the blue screen error, there are a number of additional things to try:
Load the default BIOS values - resource conflicts and timing issues can be caused by incorrect BIOS settings.
Update the BIOS - especially after adding new hardware or installing a Windows service pack this can help fix issues.
Update Windows - missing updates, including service packs can be a source of stop errors.
Check your system - run a virus scan and spyware scan after updating your definition files.
Driver rollback - if you have recently updated a driver, you can use the driver rollback to revert back to the previous driver version.
hope it helps, if so rate the solution
Nov 29, 2010 | Acer Aspire 3690-2196 Notebook
Blue Screen
The blue screen (known as the blue screen of death or BSOD) is usually caused by hardware failure. If you have the warranty available, you can contact Durabook and they will be able to assist you with that problem.
Oct 08, 2009 | Twinhead DURABOOK D15TS (D15TS17TL80M3H)...
reinstalled xp after major virus infection.. cant find propper bios driver. Windows start up and immediatly i get the blue screen of death! ;)
there is something to checkout for u. reinstall windows xp and do not install any driver just checkout that ur system is running properly or not. if yes then install one driver at a time and check the system that any blue screen appears or not. if any blue scrren appears then remove that driver and go for the latest version of that device driver. reinstall the xp from good media i.e it should contain all the reuired files and dont skip any files from installations.
Sep 05, 2009 | MSI Computers & Internet
240 people viewed this tip
David Payne
David Payne
