Tip & How-To about Coby Kyros 716829701508 Tablet PC
How To Fix Your Appslib Error On Your Coby Kyros
First, make sure the wireless is on and working. You may require the Appslib update.
The following will guide you through Installing the Windows software, Kryos USB drivers, and updating your Appslib:
  1. Download and install The Java Development Kit 6 here: https://cds.sun.com/is-bin/INTERSHOP.enfinity/WFS/CDS-CDS_Developer-Site/en_US/-/USD/ViewProductDetail-Start?ProductRef=jdk-6u24-oth-JPR@CDS-CDS_Developer
  2. Download and unzip the android-sdk-r07-windows.zip file to the C: drive on your computer: http://developer.android.com/sdk/index.html
  3. Go to the android-sdk-windows folder that you unzipped
  4. Launch SDKManager.exe
  5. Under choose which package to install, click accept all. This will download the Android USB drivers. This part may take around 30 minutes or more to complete.
  6. Once the download is done, close the SDK Manager.
  7. You should now see a folder called usb_driver. Open that folder.
  8. You will see a file called android_winusb.inf. Replace that file with the one downloaded here: http://rapidshare.com/files/435451166/android_winusb.inf
  9. Plug in your Kyros device. Windows will still not find the driver for the device, but go into the Device manager, and select AndroidEclair, and update driver, browse my computer, let me pick from a list of device drivers on my computer.
  10. Click "Have Disk" and browse to the c:\android-sdk-windows\usb_driver folder. Double click on android_winusb.inf.
  11. Select Android ADB Interface.
  12. It will then come up with some messages about this is unsigned or something, are you sure you want to do this, click yes or continue.
  13. Then it will install the driver and detect the kyros.
  14. Download appslib_2.apk here: http://files.appslib.com/apps/marketplace/v2/Appslib_2.apk
  15. Make sure you have external SD card (optional)
  16. Make sure your wireless is setup, on, and works.
  17. Under Settings (press the M button on the home screen to access settings)
  18. Select Applications, and make sure Unknown Sources is checked.
  19. On the Force prompt, select wait.
  20. If step 19 doesn't work you have 3 choices: A: call their customer service B: return to the home screen or C: Go to step 21
  21. Get the Droid Explorer for your Windows PC
  22. Make sure your KYROS is connected to the PC and launch DROID Explorer.
  23. Now you can uninstall apps or install apps.
  24. You need to download Appslib_2.apk, if you haven't already, click here and download the file to your PC.
  25. Uninstall the old Appslib before you install the new version Applib2.
  26. Transfer the Appslib_2.apk file to the [DOWNLOAD] folder on your device. Unplug your device.
  27. Open the File Manager on your tablet, go into the Download folder, and tap twice on the Appslib_2.apk file that you will find there to start the installation.
  28. Follow the on-screen instruction to install this newer version of the Appslib applications.
  29. At the end of the installation, select: "Open".
If you have an app that won't install correctly or is not working at all, you could try and download the Appslib update or upgrade here: http://www.cobyusa.com/?p=prod&prod_num_id=10498&pcat_id=1013
An alternative to the Appslib is Andexplorer, available here: http://www.lysesoft.com/products/andexplorer/index.html#download
Coby Kyros 716829701508 Tablet PC Logo
i changed the operating system now i have windows 7 on the compaq tc1100 and now i can not use the wireless how can i fix this??
Access the manufacturer's web-site:
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=ca&prodTypeId=321957&prodSeriesId=376810&lang=en&cc=ca
and you'll see that no device-drivers for Windows 7 are available from HP.
This might mean that HP has submitted the device-drivers for your wireless adapter to Microsoft.
If so, try: http://WindowsUpdate.Microsoft.com and do a search for "optional hardware updates".
If there is a device-driver, Windows Update will offer it for downloading/installing.
Feb 26, 2011 | Compaq tc1100 Tablet PC
Process com.appslib.vending on my coby kyros tab. Any solutions?
  5. Under choose which package to install, click accept all. As a part of what it is downloading, it will download the Android USB drivers. This part will probably take like 30 minutes or more to complete.
Feb 24, 2011 | Coby Kyros 716829701508 Tablet PC
I cannot open AppsLib on my Coby Tablet.
Dec 31, 2010 | Coby Tablets & eReaders
when i go too the Appslib it dosent wrk and it says try again later and it wont never work
Dec 30, 2010 | Coby Kyros 716829701508 Tablet PC
Appslib won't download
3,834 people viewed this tip
Top Coby Tablets & eReaders Experts
Fred Block
Fred Block
Martin Murray
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
