Tip & How-To about Computers & Internet
Animate your desktop
Create a folder to save all the items website, including AVI file. Now generate HTML using an application such as FrontPage and Name your file Desktop.htm. Avi file to include page. The video file will play once To this, add the text loop = "infinite" after "FileOpen". Width and height parameters must match the screen or AVI will not fit properly. If you run your View 800x600, 1024x768 and so on, change the two figures, respectively. Save your changes and close both Desktop.htm and FrontPage . Now right-click the desktop and select Properties. Click> Customize Desktop Desktop Web New Browse. Search Desktop.htm file and click Open OK. Below is a list of web pages, the file is selected. Click OK, then Apply, then OK again to finish.
Computers & Internet Logo
How to Create a Computer File?
Do you mean "Directory" or "Folder"? Use Windows Explorer to create new folders. Files are created by applications when you save your work. Most Windows applications (like Word) can also create folders. When you click "save as", you get a new pop-up window. The picture with the yellow folder and * next to it is how you create a new folder. When you put a name at the bottom, and click "OK", that makes a file.
Oct 18, 2016 | Computers & Internet
What I do transfer of email files?
When Outlook saves items to your computer, it uses a type of data file called an Outlook Personal Folders file (.pst) (Personal Folders file (.pst): Data file that stores your messages and other items on your computer. You can assign a .pst file to be the default delivery location for e-mail messages. You can use a .pst to organize and back up items for safekeeping.). If you are using a Microsoft Exchange Server account, your items are usually delivered to and saved on the mail server. To allow you to work with your messages even when you cannot connect to the mail server, Outlook offers Offline Folders, which are saved in another type of data file called an Offline Folder file (.ost) (Offline Folder file: The file on your hard disk that contains offline folders. The offline folder file has an .ost extension. You can create it automatically when you set up Outlook or when you first make a folder available offline.) on your computer.
The primary distinctions between the two types of Outlook data files are:
The Outlook .ost files are used only when you have an Exchange Server account and choose to work offline or use Cached Exchange Mode.
The Outlook .pst files are used for POP3 (POP3: A common protocol that is used to retrieve e-mail messages from an Internet e-mail server.), IMAP (IMAP (Internet Message Access Protocol): Unlike Internet e-mail protocols such as POP3, IMAP creates folders on a server to store/organize messages for retrieval by other computers. You can read message headers only and select which messages to download.), and HTTP accounts. When you want to create archives or back up your Outlook folders and items on your computer, including Exchange Server accounts, you must create and use additional .pst files.
see here: http://www.ost.viewertool.com/
OST Viewer Tool
Jul 22, 2015 | Computers & Internet
donwload multiple files from server to client using asp.net
Sir,
//To Get the physical Path of the file(me2.doc)
string filepath = Server.MapPath("me2.doc");
// Create New instance of FileInfo class to get the properties of the file being downloaded
FileInfo myfile = new FileInfo(filepath);
// Checking if file exists
if (myfile.Exists)
// Clear the content of the response
Response.ClearContent();
// Add the file name and attachment, which will force the open/cancel/save dialog box to show, to the header
Response.AddHeader("Content-Disposition", "attachment; filename=" + myfile.Name);
// Add the file size into the response header
Response.AddHeader("Content-Length", myfile.Length.ToString());
// Set the ContentType
Response.ContentType = ReturnExtension(myfile.Extension.ToLower());
// Write the file into the response (TransmitFile is for ASP.NET 2.0. In ASP.NET 1.1 you have to use WriteFile instead)
Response.TransmitFile(myfile.FullName);
// End the response
Response.End();
private string ReturnExtension(string fileExtension)
switch (fileExtension)
case ".htm":
case ".html":
case ".log":
return "text/HTML";
case ".txt":
return "text/plain";
case ".doc":
return "application/ms-word";
case ".tiff":
case ".tif":
return "image/tiff";
case ".asf":
return "video/x-ms-asf";
case ".avi":
return "video/avi";
case ".zip":
return "application/zip";
case ".xls":
case ".csv":
return "application/vnd.ms-excel";
case ".gif":
return "image/gif";
case ".jpg":
case "jpeg":
return "image/jpeg";
case ".bmp":
return "image/bmp";
case ".wav":
return "audio/wav";
case ".mp3":
return "audio/mpeg3";
case ".mpg":
case "mpeg":
return "video/mpeg";
case ".rtf":
return "application/rtf";
case ".asp":
return "text/asp";
case ".pdf":
return "application/pdf";
case ".fdf":
return "application/vnd.fdf";
case ".ppt":
return "application/mspowerpoint";
case ".dwg":
return "image/vnd.dwg";
case ".msg":
return "application/msoutlook";
case ".xml":
case ".sdxl":
return "application/xml";
case ".xdp":
return "application/vnd.adobe.xdp+xml";
default:
return "application/octet-stream";
Thanks
Good Luck
Aug 17, 2009 | Microsoft Designing ASP.NET Applications...
JVC 3CCD Cam - Playback issue
Probably you Media Player does not support TOD formate.
It is very recent one so you need to look for new softwear.
The solution is easy
Tod file conversion, download the UNLEAD VIDEO STUDIO11.5 with the update other wise he will not work properly http://www.videohelp.com/tools/Ulead_Videostudio
http://www.ulead.co.uk/vs/features.htm
Run the program(ulead) go to Edit and on the right hand side of the screen you see icon of a folder open that and import your file (tod) when it's imported put it on the time line as well.
Now to converter to any kind of format you wish is very easy.
Open share icon right on the top next to audio icon and go to any format you wish to create.
For me I use adobe premier pro I need 720X576 I do this method.
I open in share folder the ---create video file-after I have lot of choose I select ---DV------after Pal (4:3) and I give name and destination all done.
Note:
Please don’t use DV----Pal (16:9) it will stretch the footage to much
When you import the file tod strait from your JVC will help to keep the same quality of your converted file.
Good Luck
Dec 22, 2008 | JVC 3CCD Digital Media Camera Camcorder
185 people viewed this tip
David Payne
David Payne
