Tip & How-To about Computers & Internet
Windows XP fax
If you need your PC to be able to fax, you must install the Windows XP fax. Add / Remove Programs, click Add / Remove Windows Components. In the Windows Components Wizard, select the check box next to Fax Services and make sure you have the installation CD handy.
Computers & Internet Logo
fax driver missing
Microsoft Office 2010 has a feature that lets you send Outlook, Word, Excel, and PowerPoint files as Internet faxes. This feature relies on having the Windows Fax Printer Driver or Fax Services installed on the computer to send the faxes. The Windows Fax feature is not enabled by default for all editions of Windows. If your edition of Windows includes the driver or service, you must install it before you can send Internet faxes.
Which operating system are you using? Windows 7
  1. In Control Panel, click Programs, and then click Programs and Features.
Note In Classic view, double-click Programs and Features.
  1. Click Turn Windows features on or off.
  2. In the Windows Features dialog box, under Print and Document Services, select the Windows Fax and Scan check box.
  3. Click OK.
za010077668.gif Top of Page
Windows Vista The Windows Fax Printer Driver is included in the following editions of Windows Vista: Business, Enterprise, and Ultimate.
  2. In the Windows Features dialog box, select the Windows Fax and Scan check box.
  3. Click OK.
Windows XP
  1. In Control Panel, click Add or Remove Programs, and then click Add/Remove Windows Component.
Note In Classic view, double-click Add or Remove Programs.
  1. In the Windows Component Wizard, select the Fax Services check box.
  2. Click Next.
Windows Server 2008 To create a fax server, you must install the Fax Server role. This installs the Fax Server role page, Fax Service Manager, Windows Fax and Scan (with faxing capabilities only), the Fax service, and the Fax printer.
  1. In Control Panel, under Programs, click Turn Windows features on or off.
  2. Right-click Roles, and then click Add Roles.
  3. In the Add Roles Wizard, under Select Server Roles, click Fax Server role.
Note If Print Services are not installed, you are prompted to install it.
  1. Click the users or groups that you want to send faxes.
  2. Click who you want to have access to the fax server inbox.
  3. Click Install.
Windows Server 2003 The Fax Service is included in all editions of Windows Server 2003 except the Web edition.
  1. In Control Panel, click Add/Remove Programs.
  2. In the Add/Remove Programs dialog box, click Add or Remove Windows Components.
  3. In the Windows Component Wizard, select the Fax Services check box, and then click Next.
  4. If you want to share the fax printer so that everybody in the network can send and receive faxes, click Yes.
  5. Click Finish.
Click here for fax driver
Jul 26, 2011 | Office Equipment & Supplies
MY DELL 948 WILL NOT SEND A FAX
there is a generic Fax program in windows XP. If your using the vista home basic or home edition, it does not have these function unless you install an actual fax program. If not you can install it by
for XP -go to the start -control panel -go to the windows add remove programs -add remove windows components and choose the Fax services
-Vista -go to start -control panel -programs and features -add remove windows components and choose the Fax services
hope this helps
Jun 23, 2011 | Computers & Internet
I want to delete games from Windows XP
You can't delete them but you can disable them. Go to control panel. Click add/remove programs. Click Add/remove windows components from the left side. Games is under accessories.
Jan 05, 2009 | Microsoft Windows XP Professional for PC
deleted games from xp
You can use "Add or Remove Programs" to re-install your default windows games, I hope this procedure can help you, its under windows XP Home or Professional.
1. Go to START
2. Click CONTROL PANEL
3. Then select ADD OR REMOVE PROGRAMS
4. A new Windows will appear, look for the ADD/REMOVE WINDOWS COMPONENTS.
5. Click Accessories & Utilities, make sure it has CHECK mark.
6. Click on DETAILS
7. Place a CHECK mark on GAMES, then click OK
8. Then click NEXT, additional programs will be installed.
see if the games were back already.
-mrsolution
Jun 11, 2008 | Microsoft Windows XP Professional for PC
160 people viewed this tip
David Payne
David Payne
