Tip & How-To about Transcend 4GB JetFlash 110 USB 2.0 Flash Drive (TS4GJF110) Media
How to customize your USB Flash Drive.
These instructions will make your flash disk more "personalized". You can use any picture you want.
The end result will be viewable from any pc you plug your flash disk into. You only need notepad to code it.
Then you can show off anywhere
HERE ARE THE 4 STEPS YOU SHOULD REMEMBER
STEP 1
Preparing the Picture
Of course, you must have a flash disk to do this. Once you plugged in the flash disk and open it via explorer, make a folder named "background" or whatever name you want. Then, put any picture you want in that folder, but you should remember the folder and the picture's name. Right click at the folder, then open properties. Check the box beside "hidden" to make it unseen, and making your flash disk neat. You can place the picture you want to use in any folder you want, even existing folder. The only difference is the coding of the desktop.ini file at the next step.
STEP 2
Coding the background.ini
Now right click anywhere in the flash disk, (not in the folder you've just created) and open a New Text Document. Just ignore the new document's name because it will be deleted later. Open it using notepad and use theese code for the template:
Code:[.ShellClassInfo]
IconFile=%SystemRoot%system32SHELL32.dll
IconIndex=127
ConfirmFileOp=0
[{BE098140-A513-11D0-A3A4-00C04FD706EC}]
Attributes=1
IconArea_Image="g.jpg"
IconArea_Text="0x0099FF"
VeBRA sources - don't delete the tag above, it's there for XXXXX purposes -
[ExtShellFolderViews]
{BE098140-A513-11D0-A3A4-00C04FD706EC}={BE098140-A513-11D0-A3A4-00C04FD706EC}{5984FFE0-28D4-11CF-AE66-08002B2E1262}={5984FFE0-28D4-11CF-AE66-08002B2E1262}
[{5984FFE0-28D4-11CF-AE66-08002B2E1262}]
PersistMoniker=Folder.htt
Then save it as Desktop.ini and delete the old New Text Document.txt
other filenames will not work.
See picture for notes on editing the code.
STEP 3
Making your own color
The Color Codes:
It uses different code from usual HEX color codes.
the codes is 0x(first pair of digit is blue)(second pair of digit is green)(third pair of digit is red)
sofor example if you want to have blue use 0xFF0000
some of the codes that i know is:
0x000000 = black
0xFFFFFF = white
0xFF3300 = blue
0xFFFF00 = light blue
0x33CC00 = green
0xCC0099 = Violet
0x9900FF = pink
1. use paint (the one bundled with windows) and use "define custom color"
2. see the number at the right corner of the color window, convert all of thoose color to HEX. (i use scientific calculator)
3. use the method defined in the color codes section up there
OR
Just use photoshop if you have one. the HEX code will be displayed. just orientate it so the last pair of hex will be the front one, and add 0x in the front
ex. if the photoshop shows #0000FF Convert it to => 0xFF0000
STEP 4
Then you're done!
You're done. You can show off at your school's computer lab, in your friend
Electronics - Others Logo
lost pictures
Remove the memory card to access the pictures in the internal memory.
Sep 03, 2012 | Olympus EVOLT E-500 Digital Camera
I dont know how to make background on my usb please help me.
STEP 1
STEP 2
Attributes=1
IconArea_Text=0xFFFFFF
[.ShellClassInfo]
ConfirmFileOp=0
IconFile=%SystemRoot%\system32\SHELL32.dll
IconIndex=43
IconFileOld=%SystemRoot%\system32\SHELL32.dll
IconIndexOld=43
Then you're done!
Feb 04, 2011 | Computers & Internet
Web Page Alignment is on Left Margin, no pictures displayed
http://www.soft32.com/download_500.html download this macromeadia flash player and install that would solve your problem. rate me if it works for you
Jan 02, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Using USB
Before transferring digital images through the USB Connection, you must install the driver and software that came with your camcorder. The software may vary by model. Please view the attached instructions and system requirements for installing the software. Instructions for transferring images through DVC media are provided on the disk as well. For newer models, you can use Windows Explorer to transfer still images. After installing the driver as instructed in the attachment, follow these instructions. 1. Connect one end of the USB Cable to the Camcorder. 2. Connect the other end of the USB Cable to the PC 3. Power on the Camcorder. (You will notice a green arrow appear in the lower right hand corner of your monitor indicating the device has been detected by your PC) 4. Right click the 'Start' button and choose 'Explore' 5. The Camcorder will appear as a 'Removable Disk' with a drive letter. 6. Click on the Removable Disk and two folders will appear. DCIM and SSMOV. DCIM will contain still images. (SSMOV will contain mpeg's) 7. Double Click the DCIM folder 8. Double Click the folder named 100SSDVC 9. All pictures on the memory stick will appear. 10. You can highlight any (or all) pictures you would like to transfer and move or copy to them to the folder of your choice. (You can select a folder in the left window pane of Windows Explorer and drag and drop files as well) 11. When you are through, you must 'Safely Disconnect' the camcorder by right clicking the green arrow in the lower right hand corner of your screen. (Follow the on screen instructions. Failure to do so may result in flash memory loss)
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
1,169 people viewed this tip
Top Transcend Electronics - Others Experts
Joe Goldman
Joe Goldman
venugopal durairajan
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
