Tip & How-To about Computers & Internet
Did You Know (#3: Compatibility Issues)
So you just installed a program for Windows 7 which worked on Windows Vista, but now you are coming across nothing but problems. A lot of times these issues can be resolved simply and easily. Here's what you can do. This is to be understood that there is no patch for Windows 7 on the manufacturer's website:
If this program is in your Start Menu, right-click on it and select Open File Location. Right-click on the program you want to use and select Troubleshoot Compatibility.
In similar occasions when you attempt to start up a Setup.exe file, you may be prompted with the message that your current OS (Operating System) is not supported. You can use the same means to 'Troubleshoot Compatibility' in this situation too. This won't always work, but it's better than just sitting there moping, right?
In the Troubleshoot Compatibility Wizard, all you have to do is select the option that says, "This program worked in a previous version of Windows", then hit Next. Windows will do the rest.
Again, this won't always work. In certain situations the program you are using may just not have that compatibility and you may need to look for an alternative program to use to satisfy your needs.
Computers & Internet Logo
i cant install nvidia geforce fx 5600 on windows 7ultimate 32bit O.S any solution?
get the vista 32bit drivers for it,ive come across the same problem a few times with 7 on outdated hardware and for me the vista drivers just worked as well
Mar 08, 2011 | Microsoft Windows Vista Ultimate Edition
Would upgrading from vista to windows 7 speed up the response of my computer ?
yup definitly you will have to upgrade windows 7 one day or another many coll features but going from vista to 7 is no problem at all
reffer to this
upgrade paths
Apr 11, 2010 | Microsoft Computers & Internet
when i turn on my toshiba A300 it's working until i get to my user's password and after that it stops running i get only black screen never it turn on
ahh yes..
I have come across this problem before when I worked at this computer repairs shop and all you need to do is re - install Vista, or even try out Windows 7, a Free Operating System (OS) and has all the great features and glamor as Vista but has the performance and system requirements as XP.
But, if you still want Vista, get your recovery disks and use them so you do not have to install every driver for your laptop, again!
Please notify me of any problems and/or concerns.
Hope I helped
- donman92
Jul 17, 2009 | Computers & Internet
Ages of Empires II will not work on Vista on my laptop
All this bit is irrelevant
"Age of Empires II has stopped working" then in smaller writing it says "Windows can check online for a solution to the problem" it then gives me the choice of checking online or closing the program, I click the "Check online for a solution and close the program" option, it then comes up with another window telling me "Windows is looking for a solution for the problem"
This is just a message saying Winderz has no idea what is going on and doesn't know how to fix.
Vista is the pits. You need Windows 7 at least. Is this Age of Empires a bootleg copy on DVD or CD by any chance? The disc is corrupt.
Mar 29, 2017 | Microsoft Age Of Empires II: Conqueror 2.0...
Kodak 5100 won't print with Windows 7.
I've had the same problem for some time, but recently found a fix. Those sneaky folks at Kodak updated their Vista driver for the ESP series, and it works with Windows 7 now. Oddly enough they haven't advertised this fact, but it works none-the-less. Now, you're going to have to uninstall the Kodak Home Center, the driver and anything else associated with Kodak. You need to manually go through the Program Folder and delete anything Kodak. Make sure you set explorer to show hidden files/directories, and go to Program Data and delete any thing Kodak. Finally go to users appdata and delete anything Kodak in all the sub folders there. Then download and install the new May 1 drivers from the Kodak site:
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9103/13657/13660&product=EKN035329
Note: They are the Windows Vista drivers, but they do work on my Windows 7 machine.
You'll also notice that they've updated their installer program.
Hope this works for you, and if it does spread the word!
Mar 06, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
102 people viewed this tip
David Payne
David Payne
