Tip & How-To about Computers & Internet
Customise sounds
Select the sound that plays when Windows XP to perform a specific task or action. Go into the Sounds and Audio Devices in Control Panel and select the Sounds tab. Select an event and then select the desired sound.
Computers & Internet Logo
how to deactivate shift key sound on windows keyboard
Right click on the speaker icon in the bottom taskbar select playback devices then sounds tab scroll through all device sounds select it then from the drop down list select none
this will vary depending on your operating system
or
Click "Start."
Click "Control Panel."
Click the "Sound" icon.
Click the "Sounds" tab.
Click on the listing for the sound that currently plays when an action is performed on your keyboard.
This will select it. Click the drop down menu on screen and select "None." Click "Apply" to disable the keyboard sound in
hope this helps
Oct 10, 2012 | Computers & Internet
I have a set of Saitek A250 Wireless speakers and a set of Logitech speakers. I can't get iTunes to play on the Saitek speakers, but Windows Media Player and normal Windows sounds do without issue. I'm running Windows XP SP3 and iTunes 10.2.2.12 (HP). The speakers were working on previous versions of iTunes
click start control panel sounds and audio then select audio make sure the default player is the media you want to use as your default sounds also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
hope this helps
May 22, 2011 | Saitek A-250 Computer Speakers
My headset is playing voices really quietly. Also while in game that uses 3-D sound I could only hear things to my left and right
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
also click start control panel sounds and audio devices then select voice then select volume from the microphone you can increase the volume or you can test your harware in XP in W 7 click start control panel hardware and sound manage audio devices recording right click on microphone you can configure speech recognition
or you might have to boost
http://www.filebuzz.com/fileinfo/55139/3DP_Chip.html
Windows 2000, Windows XP, Windows 2003 , Windows Vista
3DP Chip was designed to help you to enumerate your devices such as CPU, MOBO, Graphic Card, Sound Card and Ethernet Card and provides device Drivers through the internet.
3DP Chip Copyright notice:
Pirated Software Hurts Software Developers. Using 3DP Chip Free Download crack, warez, password, serial numbers, torrent, keygen, registration codes, key generators is illegal. We do not host any torrent files or links of 3DP Chip from depositfiles.com, rapidshare.com, megaupload.com etc.
hope this helps
Apr 30, 2011 | Computers & Internet
it won't extract m cd. it just says scanning for devices and nothing happens
For stuck CD do this:
Hit Ctrl,Alt and Delete all at the same time> Windows Task Manager should open> Click on the "Applications Tab"> Click End Task to close all Apps.> Now go to your Cd/Dvd player hit the eject button on the front.> Remove CD.
Now for your device problem try this:
To specify your preferred audio devices for playback or recording in Windows, do the following:
Windows 98, 98se, ME:
1. In Control Panel, double-click Multimedia or Sounds and Multimedia.
2. On the Audio tab, select the devices you want in the Preferred Device boxes.
3. Click the Use Preferred Devices Only check box to select it.
4. Click OK.
Windows 2000 and XP:
1. In Control Panel, double-click Sounds and Audio Devices.
2. On the Audio tab, select the devices you want in the Default Device boxes.
3. Click the Use only default devices check box to select it.
4. Click OK.
Windows Vista:
1. Go to Start > Control Panel
2. In Control Panel, select the option that says Hardware and Sound
3. Under the listing for Sound, select Manage Audio Devices
4. Under Recording and Sounds tabs, you will find all available devices. To set a default device, right click on one of them and select Set as Default Device.
Windows should now be configured to use these devices for both playback and recording.
This should fix your problem, if not use link to go to Sony support. Use the E-Mail option for a faster solution.
http://www.sonycreativesoftware.com/support/
Oct 08, 2010 | Sony Sound Forge 8.0 for PC
158 people viewed this tip
David Payne
David Payne
