Tip & How-To about Audio Players & Recorders
How to start your new ipod for beginners.
Just got a new ipod,congratulations.But it doesn't work straight from the box.When you start it up the first time.a usb and itunes symbol will appear.To begin you have to have a computer or laptop with the latest itunes installed.This is required to even startup your ipod.If you have itunes installed plug usb cable from ipod into computer or laptop and itunes will recognize your ipod and begin sync.Keep in mind this first sync will join this ipod with itunes on this computer or laptop then you can name it and do settings.
Restore software for ipod 16GB touch
i would be checking the usb lead before doing anything or even replacing it with a new one make sure iis securely connected
the cable near the iTunes symbol represents a problem with the cable
and the cd will not not be able to activate without a connection
Connect one end of the USB sync cable to one of your computer's unused USB ports, and connect the other end to the bottom of the iPhone or iPod Touch.
If iTunes does not start on its own, run it using the desktop or Start menu shortcut.
When iTunes starts, you should see an icon for the iPhone or iPod Touch on the left side of the window.
Click "Summary" in the right pane of the window if it is not already active.
Click the "Restore" button to begin the device restoration process.
ITunes displays a message asking if you want to save the contents of the device to your computer before restoring it.
If you have not backed up the device already, click the "Back Up" button.
If you have already done this, click "Don't Back Up."
Click "Restore." ITunes clears the data from your iPhone or iPod Touch and reinstalls the device's original firmware.
The screen of your iPhone or iPod Touch may shut off while iTunes works.
Do not remove the USB sync cable.
When iTunes is done restoring the device, it displays a message letting you know that the device is about to restart.
Click "OK" to restart the device. If you are restoring an iPhone or iPod touch, wait for the "iPhone / iPod touch is activated" message to appear on the screen of the device before you disconnect it from the computer.
You may now restore your backup of the device or remove it from the computer.
hope this helps
Sep 15, 2012 | Apple iPod touch
My son updated my 2g ipod touch on his (older?) computer. It is frozen now & won't go past a screen w/the itunes symbol & the usb plug. It will not restore. I have uninstalled & reinstalled itunes. Can you help?
  • This isn't an iTunes problem. While the iPod is displaying this logo, you need to plug it in to a computer that has iTunes open beforehand.
  • Try using another computer with iTunes installed, or another USB cable for the iPod. Try to restart by holding the sleep and home buttons for about 10 seconds.
  • If this still doesn't work, take the iPod to your local Apple store, where they can check for any hardware problems that may have occurred.
Jun 29, 2011 | Apple iPod touch
Ipod Touch 8gb problems
Hi K,
Ahhh, everything has suddenly become very clear :) All is well and there is nothing wrong with your ipod. Heres what you need to do.
  • First, install the very latest version of iTunes onto your PC or Mac - Download it from http://www.apple.com/itunes/download/
    Tip: Uncheck the two boxes and don't enter your email address
  • Once that's installed, start iTunes up and connect your iPod to the computer via a USB2 port (any on a laptop but not through a hub; on a PC tower use only one of the USB ports on the rear of the machine, ie, none of the ports on the front) - It's gonna need charging (That's what the Batt symbol is showing) so leave it for a good 2hrs.
  • While it's charging I'd recommend spending some time familiarizing yourself with the user guide - it explains alot of these symbols and more importantly how to get started with your new iPod. You can download the manual from here: http://support.apple.com/manuals/#ipodtouch
  • When it's good and charged then follow the onscreen instructions for the iPod on iTunes. You have to register the iPod first before you can use it. So once you've done this all will be well in the world for you. See page 5 and 6 of the manual.
All the best
Sean
PiDigital
Dec 27, 2008 | Apple iPod touch
iPod shuffle 1st gen. Not Recognized By PC
Try a different USB port first. Here are some other suggestions:
Connect iPod shuffle to a high-power USB port on your computer. iPod shuffle may
need to be recharged.
â Make sure you have installed the latest iTunes software from
www.apple.com/ipod/start.
â Try connecting to a different USB port on your computer. Make sure iPod shuffle is
firmly seated in the dock. Make sure the USB connector is oriented correctly. It can be
inserted only one way.
â iPod shuffle might need to be reset. Turn iPod shuffle off, wait five seconds, and then
turn it back on again.
â If there is no status light (or the status light is dimmed) and iPod shuffle doesn’t
appear in iTunes or the Finder, the battery may be completely discharged. Let
iPod shuffle charge for several minutes to see if it comes back to life.
â Make sure you have the required computer and software. See “If you want to doublecheck
the system requirements” on page 25.
â Try restarting your computer.
â If none of the previous suggestions solves the problem, you might need to restore
iPod software. See “Updating and Restoring iPod shuffle Software” on page 26.
â If restoring iPod shuffle doesn’t solve the problem, iPod shuffle may need to be
repaired. You can arrange for service on the iPod shuffle Service & Support website at
www.apple.com/support/ipodshuffle/service.
Jun 09, 2008 | Apple iPod shuffle MP3 Player
311 people viewed this tip
 Grubhead
Grubhead
