Tip & How-To about Garden
Chainsaw engine seizures, myths and facts.
Nobody likes to be told there chainsaw has seized up, the very nature of the word seized implies the the machine is solid and will not turn over, the reality is the piston has lost the oil film between it and the cylinder wall, it now has metal to metal contact, material from the piston skirt now transfers to the cylinder wall, the cylinder fins are very effective and the piston cools very quickly, and the engine will now rotate,so technically it is not seized up, unfortunatly the damage is done, the material from the piston has scuffed up over the piston ring, which is now stuck in, compression is lost , and the machine now refuses to start.
Stock answer from the dealer is usually a simple one line answer, no oil in the fuel, but this is not always the case, most engine seizures come under the heading of a lubrication breakdown, the reasons for this are as follows.
Insufficent two stroke oil in the fuel.
Poor quaility two stroke oil in the fuel.
Incorrect grade of oil in the fuel.
Incorrect carb settings, causing over speeding.
Inadiquate servicing.
Poor chain maintenace, causing over loading.
Fuel system blockages, causing lean mixture.
Blocked cooling finns.
Operator miss use.
Engine air leaks, causing lean mixture.
Stale fuel, water contaminated fuel.
As you can see there are many reasons for a lubrication failure, you must remember this small engine is reving at anything up to 14000 rpm probably three times the rpm of your motor car engine flat out,and in a very hostile environment, the machine is air cooled, and basically a stationary engine, so all the cooling air is supplied by the vanes on the flywheel via the starter cover grill, if you allow dirt and debris to collect in the starter cover vents,you have now effectivley cut off the cooling air to the cylinder. Poor chain sharpening can and will cause over loading, and in turn increased cylinder temperature. Clogged fuel filters, dirt in the carb, dirty fuel, incorrect carb settings ,all increase engine revs, increased revs and lean fuel oil mix to the cylinder results in engine over heating and possible seizure. Engine air leaks, either through leaking gaskets or crank seals will also increase engine speeds and possible cylinder failures.
If you suspect an engine seizure, or your saw will unexplainably not start, remove the muffler, this is normally only held with a couple of screws, check the condition of the pistons exhaust skirt ( this is the hottest part of the engine, betwwen the centre of the piston and the opposite side to the flywheel, as the flywheel side runs a little cooler ) any signs of piston scuffing,and the engine has seized, and will require further investigation.
Other possible reasons for cylinder seizures are main bearing failures, or foriegn objects entering the saw through the inlet port. When removing clutches, or flywheel nuts, you should never enter anything into the cylinder to lock the piston, piston stops, bits of starter rope etc, these items can damage the piston, or get caught between the cylinder and the piston.
A final thought on two stroke oil, there are many different makes and colours of oils out there, what you need to ask youself is, how many of these oil suppliers actually produce a chainsaw engine? how do they know the lubrication requirements of the engine? why would anybody spend there hard earned money on a good saw, and then buy the cheapest oil they can find, always buy the best two stroke oil you can, preferably from a chainsaw manufacturer, and to be mixed at 50-1 ( remember the environment, if not that remeber you are breathing an amount of the exhaust gas in )
And finally a piece of trivia, an engine running for two hours a day, five days a week, running a 9500rpm the crank has rotated 1.7 million times in the first day, the diaphrams have cycled 3.42 million times, an engine running at 13500 rpm the spark plug sparks 225 times a second.
I hope you find this interesting and informative.
Garden Logo
Hi, I have the 1600 NG tankless water heater. Everything works great, but I installed low flow hot faucets throughout the house and now the igniter will not click on. It works for the washing machine. And I have turned up the "turn on" sensitivity all the way up. I have to turn on all of the faucets in the house to get the heater to turn on. Then it does not stay on when I turn them off one at a time. If I turn off and on the water quickly, it turns on; with all of the hot faucets in the house turned on. Help!!!!
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html#flow
1) Tankless require minimum flow rate before burner will activate.
2) Sounds like the water pressure drops quickly when faucet turns on. This implies combination of problems including sediment build up inside lines, crossover at single-handled faucet, or sediment filter clogged or water softener clogged.
3) Low flow faucets can reduce needed flow rate.
4) Other problems can contribute: sensor failure, loose wires, PC board failure, high temperature setting, cold incoming water temperature during winter months.
Jul 20, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
the auger is spinning the belts are fine but it won't throw snow. The impeller doesn't seem to be turning and if it does it turns slow.
Check for a sheared key at the drive pulley which drives the impeller. Is there a shear pin at the impeller itself? Can you watch the drive pulley while it is running. The belt tension clutch my require adjustment to give solid drive to the pulley. Check for excess friction in the impeller drive (engine off)--a bearing may have seized. Hope some of this helps!
Jan 09, 2011 | Garden
Brand new saw, started it and it seized, piston is now seized
Did you mix the proper amount of oil with the gasoline? Are you sure the piston is seized and it isn't just that the chain is too tight for the sprocket to turn?
Oct 30, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Ford Thunderbird 1994 A/C compressor
Not necessarily. The fact that the vehicle is jolting when the a/c compressor is turned on could be to the fact that the engine is designed to rev higher when the a/c is on. If the a/c works, then the compressor is working and it hasn't seized. If this is the case, you may have a bad motor mount. This is more likely if you feel the motor lurch when you jump on the gas pedal. Hope this clarifies your problem and Good Luck!
May 02, 2009 | 1994 Ford Thunderbird
Chain locked
Can you turn the chainsaw over ( pull start cord s l o w l y .) if not your friend may have seized the engine. ( no oil in fuel, assuming it is two stroke.) then remove the chain and bar ( usually a couple of nuts/bolts) and try turning it over again. If it turns over or even starts, then the chain bar or clutch may need replacing. good luck.
Nov 02, 2008 | Husqvarna Chain Saw 20" Bar
10,601 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
john h
