Tip & How-To about Computers & Internet
How to show/hide your Network Connection icon in the Windows XP System Tray
1. You will need to open your Control Panel. Note there is several ways to do this.
XP Start Menu it is on the right side of the start menu.
Classic Start Menu it is under Settings
2. Next you need to make sure you are in classic view. Note if you have not been in Control Panel before you most likely will not be in classic view. To put Control Panel in classic view click on the Classic View option in the upper left hand corner.
3. Now Control Panel should look something like this. Here is where you would click on Network Connections.
4. Right click on the network connection that you want to change the option on and select properties.
5. Making sure that you are on the General tab at the bottom of the window you can check or uncheck the option "Show icon in notification area when connected"
6. After you have made your changes click on the OK button and the window will close.
Computers & Internet Logo
enable wireless for aspire kav60
Which Operating System?
The wireless button is for turning the wireless on or off, it sounds like you have the wireless adapter disabled.
Click Start/Control Panel or Start/Settings/Control Panel and look for Network or Network and Sharing.
If windows XP: when you open the Network just right click on the wireless connection and select Enable.
If windows Vista or Windows 7 when you open Network and Sharing look over on the left and select Manage Network Connections. Right click on the wireless connection and select Enable.
Jun 01, 2012 | Computers & Internet
I thought that once I installed the Netgear I would have an icon in my system tray showing the strength of the available wireless connection. My computer is running Windows XP. How do I get that icon in my system tray? Thank you for your assistance!
On each computer that has a wireless connection to the internet through your router you can enable the status icons as follows:
Click on Start and Control Panel.
Verify that Control Panel is in the "Classic Mode"
Double click on "Network Connections"
Right click on your Wireless Network Connection
Click on Properties
At the bottom of the "general Tab" in the Wireless Networks dialog box, place check marks in:
"Show icon in notification are when connected"
"Notify me when this connection has limited or no capability"
Then Click on OK and exit Control Panel.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Jan 29, 2011 | NetGear WGR614 Wireless Router
XP Home W/ No Network System Tray Icon
control panel-network connection-right click on "local area connection" at bottom select "properties" click a check in the box that says "show icon in notification are when connected"
Dec 29, 2009 | Sony VAIO VGN-T150L PC Notebook
Go to Control Panel >> Network Connection >> Right Click - Properties >> there's 2 check box, and check for " Show icon in notification area when connected.
Dec 29, 2009 | Sony VAIO Notebook
345 people viewed this tip
David Payne
David Payne
