Tip & How-To about Computers & Internet
How to Restore a Laptop to Original Settings
Are you using your laptop from an extended period of time? If yes, then obviously your laptops' working speed has been decreased. You have huge number of files in your laptop's hard disk which cause low speed in processing the instructions. These files are not affecting the speed of laptop only but they also create problems to you when searching any particular file. Most of these files are not in use and probably these files will not be used in future. So, you should delete them from your hard disk.
What should be done to remove these files from your laptop's hard disk? There is a technique which is commonly used to make hard disk space free and keeps laptop with original setting. This technique is known as "Restoring".
Sometime, your Windows operating system may crash and you don't know what to do. You can use the same tehnique.
You can restore your laptop to original setting through the following instructions:
To restore the laptop into its original setting you need a Recovery Disk which comes with the laptop and it is also available in market. Just get this CD and take the following steps:
- Place Recovery CD in your CD-Rom to operate the installation for restoring the laptop.
- Restart your laptop. Through restart, your laptop will auto detect the CD.
- After detecting the CD, your laptop will ask you "press any key to continue..." If your laptop will not ask that's mean there is something wrong with your booting setting, CD-ROM, or CD. Check them one by one and make sure everything is perfect.
- Press the keyboard key according to your laptop's model that brings up the recovery menu. Most common keys for the recovery menu are "F2," "F8," or "Ctrl" and "F11".
- Select a language from menu at the top of the screen and click on "Next" button. Language selection will show the instructions in your selected language.
- Select the field "PC Restore," "Repair Your Computer" or something similar. Then click on "Next" button.
- Then check on at "Restore" and then click "Enter". This will start the process of restoring the laptop.
- Once the restoring process has been completed, click on "Restart" button.
Finally your laptop has been restored to the original setting and extra files have been deleted from your Hard Disk.
Computers & Internet Logo
Hello.. I'm having problems with my Lenovo Laptop.
Remove all cookies from your computer and try. If it is not working properly then go to the store from where you bought it supposed to be in warrantee period sellers will fix your problem if your laptop is in warrantee period.
Mar 15, 2014 | Lenovo Computers & Internet
IS IT SAFE TO KEEP THE LAPTOP BATTERY OUT FOR LONG PERIODS
Yes, it should be fine to remove the battery from the laptop if it is not being used, as there would be a minimal drain on the battery if left installed for an extended period.
Keeping the battery at approximately 75% charged should also be fine and would be recommended as part of a practice to extend the battery life that is advised with common battery maintenance instructions.
Jan 05, 2012 | Dell Computers & Internet
how to maintain compaq cq 40 to get better battetry backup for more than 2 hours
Tips for getting more from a notebook battery.
1. Turn off Wi-Fi and BlueTooth - Most laptops have shortcut keys to instantly disable wireless networking.
2. Don't play computer games, music or DVD movies - Multimedia activities drain laptop batteries.
3. Disconnect all external device like PC Card modems, Firewire, USB devices and optical drives. Use the notebook touchpad instead of an external mouse.
4. Adjust your screen brightness - Dimming your display saves battery power.
5. Tweak Windows Power Options - Choose a Laptop power scheme that turns off the notebook monitor and hard disk after 10 minutes of inactivity.
6. Decrease or mute the Laptop Speaker Volume.
7. Turn off all scheduled tasks.
8. Turn off Auto-save features in Microsoft Office and other applications.
9. If your PC has a built-in wireless card, turn it off or disable it when not in use.
10. Programs that are run from a CD or DVD can be copied to and run from the hard drive, which typically consumes less power than an optical drive.
Looking for the longest battery life laptop ? Actually, many factors affect the amount of time that a laptop battery can deliver power before it must be recharged.
How to extend laptop battery life? Here are some more tips to improve your notebook's battery life:
1. If you do not use your laptop for extended periods of time (a week or more), remove the battery pack from the laptop.
2. Do not expose the battery to high heat or freezing temperatures. Do not leave your battery in your car in the summer. Hot batteries discharge very quickly, and cold ones can't create as much power.
3. Make sure to plug your laptop charger adapter into a UPS and not directly into a power outlet or surge protector.
4. If you have a nickel-metal hydride battery, completely drain and recharge the battery once a month to maximize its capacity to hold a charge.
5. Fully charge new battery packs before use. New pack needs to be fully charged and discharged (cycled) a few times before it can condition to full capacity.
6. For laptops that work as Desktop Replacement, the battery should be re-installed every 3-4 weeks and allowed to fully discharge.
7. Leaving a battery in a laptop while using an electrical outlet for long periods of time will keep the battery in a constant state of charging up and that will reduce the life cycle of the battery.
Battery-saving sleep modes: Should I use Stand By or Hibernate
Standby mode
Use standby to save power when you will be away from the computer for a short time while working - your monitor and hard disks turn off, all applications and open files are stored in RAM. When you want to use the computer again, it comes out of standby quickly, and your desktop is restored exactly as you left it.
Hibernation Mode
Use hibernation to save power when you will be away from the computer for an extended time while working - your computer shuts down to save power but first saves everything in memory on your hard disk. When you restart the computer, your desktop is restored exactly as you left it.
When you choose Start, Turn Off Computer in Windows XP, your options are Stand By, Turn Off, and Restart. To Hibernate, place the cursor over Stand By, then hold down Shift and click.
Jan 12, 2010 | Computers & Internet
Battery usage
Yes simply because of the heat your computer makes it will deteriorate faster. If used for long periods take battery out and store in room temperature place. Remember that not using the battery for long periods(days-weeks) can be bad for your battery.So try to use it once in a while.
Mar 14, 2009 | Computers & Internet
8,914 people viewed this tip
David Payne
David Payne
