Tip & How-To about Cameras
Organising images
It 'important to organize your digital photo files on your computer, but you can also arrange on paper. contact sheet of A4 paper, with small thumbnail size of each photo and information on where each file has been saved, you can make life much easier!
Cameras Logo
paper feed jams on right hand side after I pulled bits of an A4 that came out ripped
Bruno:
You did not get all the pieces of that A4 paper out of the paper path. There is still a small shard of paper in the right side of the paper feed area. Use a flashlight to look carefully in the paper feed area and gently use tweezers to remove the piece of paper. If you pulled the sheet of A4 paper backwards out of the feed area, you may have dislodged the paper feed sensor (a small plastic finger that sticks down in the paper path to tell the printer that the paper has passed.) Be careful with the tweezers... if you break that sensor, there is no fixing it.
Jun 21, 2015 | Epson Stylus Photo R2400 InkJet Printer
with the espon TX810FW can i print on clear paper / over head projector sheets?please answer quickly it is important
You can get special overhead film for your Epson printer. It is coated for use in your printer, and has a backing sheet so the paper sensor can see that paper is loaded.
Sep 03, 2014 | Office Equipment & Supplies
How can I print only black and white
If you're printing the photos yourself and it's film then you have to use black and white film, chemicals and paper. Otherwise, shoot black and white film and send it to a photo lab. If you're talking digital then you're in the wrong catagory here. This is film cameras only.
Jan 29, 2014 | Photography
how to put the paper in the printer?
Loading Paper
1 Adjust the guides to the position for the paper size you are using.
2 Fan the paper well.
Push down the paper lever. Load the paper (with the lever down). Make sure the print side is toward the fax machine and the paper level is stacked below the paper mark. The feeder can hold up to 200 sheets of paper, or up to 10
envelopes.
Acceptable Paper
The FAX/MFC can handle paper that has the following specifications.
But please note that you can receive fax messages only on Letter, Legal and A4 paper. If you use legal or A4, change the Paper Size setting: (Menu/Set, 1, 1.)
Paper Type Paper Size
Cut sheet Letter, A4, Legal, B5, A5, Executive,
Custom size 2.75-8.5 × 5-14 inches (70-216 × 127-356 mm)
Envelopes DL, C5, COM-10, Monarch
Post Card 2.75-8.5 × 5-11 inches (70-216 × 127-279 mm)
Organizer Day-Timer® J, K, L, M 2.75-8.5 × 5-11 inches (70-216 × 127-279 mm)
Labels and Transparencies 2.75-8.5 × 5-14 inches (70-216 × 127-356 mm)
Dec 20, 2010 | Brother IntelliFAX 3800 Plain Paper Laser...
Photoshp CS2 print differnet photos on one sheet photo paper
for printing multiple photos in different layouts, photoshop might not be the best program.
You can howerver do it, here is how:
Open a new document with the preset letter (if your printer prints letter format) or Din A4 (if it prints A4 pages).
Open the three (or more, or less =) photos, so that you have four windows in photoshop (one is the blank page)
now with the move tool (tool palette -> top left corner) drag and drop the photos onto the blank page you created.
They might be too big (or too small). In order to change that, hit strg-T (if youre mac thats apple-T).
This will show a frame around the photo, where you can drag the corners to enlarge or shrink the photo. Hold down shift while doing that so the picture stays in proportion (youll see what i mean).
When the pic is the right size, hit the okay button on top of the workspace or just hit enter.
arrange your photos and hit File->Print with Preview (or something like that)
Now you can see how the printer is going to print the page.
If its cut of, youll have to go to Page Setup and set it to Landscape mode (or Portrait)
When you hit okay, Photoshop might tell you that the printer will cut off edges of your picture. This usually isnt true because the edges of your page should be white anyways (most printers dont print to the border of the page, so calculate 1,5 cm or so)
so just hit proceed and print
I hope this wasnt too complicated, come back with more questions if you want =)
also, be sure to try picasa from google for organizing photos (i think you can print from there too)
Jan 01, 2009 | Keystone Adobe Photoshop CS2...
209 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
