Tip & How-To about Cell Phones
Changing Language Settings on Nokia phones and other products.
Take the following steps to change your language to English. 1. Turn your cell phone on, andpress the menu button to begin viewing the menu options of your phone. 2. Scroll through the menu optionsof your phone until you come to a settings option. Every cell phone has adifferent basic set up, but they all have "settings" areas, where thebasic phone settings are located. One you have found the settings option,select it. The settings option will open a list of basic cell phone functions.Some cell phones have larger groups that are then broken further into smallerones, and other phones have a bunch of small individual settings options. 3. Look for the option undersettings that says system, display, display info, or language, and choose it.Whichever of these options your cell phone has, the outcome will be the same,so don't be discouraged if your cell phone has a slightly different set up thanother cell phones. 4. Choose your desired cell phonelanguage from the list and choose it, if your cell phone had a language optiondirectly under settings. If not, then look for the language option under the system,display, or display/info options, and then choose your language from the listit provides 5. Turn your phone off and then backon again, just to ensure that the new language change did take effect, and willremain. Your language settings should now be changed, and you should be viewingall functions of your cell phone in your newly chosen language.
Cell Phones Logo
change language from german to english
    • 1 Turn your cell phone on, and press the menu button to begin viewing the menu options of your phone.
    • 2 Scroll through the menu options of your phone until you come to a settings option. Every cell phone has a different basic set up, but they all have "settings" areas, where the basic phone settings are located. One you have found the settings option, select it. The settings option will open a list of basic cell phone functions. Some cell phones have larger groups that are then broken further into smaller ones, and other phones have a bunch of small individual settings options.
    • 3 Look for the option under settings that says system, display, display info, or language, and choose it. Whichever of these options your cell phone has, the outcome will be the same, so don't be discouraged if your cell phone has a slightly different set up than other cell phones.
    • 4 Choose your desired cell phone language from the list and choose it, if your cell phone had a language option directly under settings. If not, then look for the language option under the system, display, or display/info options, and then choose your language from the list it provides.
    • 5 Turn your phone off and then back on again, just to ensure that the new language change did take effect, and will remain. Your language settings should now be changed, and you should be viewing all functions of your cell phone in your newly chosen language.
May 14, 2011 | Alcatel Cell Phones
how to change the language into english pl answer me?
Apr 24, 2011 | Cell Phones
langue change options
Take the following steps to change your language to English. 1. Turn your cell phone on, and press the menu button to begin viewing the menu options of your phone. 2. Scroll through the menu options of your phone until you come to a settings option. Every cell phone has a different basic set up, but they all have "settings" areas, where the basic phone settings are located. One you have found the settings option,select it. The settings option will open a list of basic cell phone functions.Some cell phones have larger groups that are then broken further into smaller ones, and other phones have a bunch of small individual settings options. 3. Look for the option under settings that says system, display, display info, or language, and choose it.Whichever of these options your cell phone has, the outcome will be the same,so don't be discouraged if your cell phone has a slightly different set up than other cell phones. 4. Choose your desired cell phone language from the list and choose it, if your cell phone had a language option directly under settings. If not, then look for the language option under the system,display, or display/info options, and then choose your language from the list it provides 5. Turn your phone off and then back on again, just to ensure that the new language change did take effect, and will remain. Your language settings should now be changed, and you should be viewing all functions of your cell phone in your newly chosen language.
OR BETTER STILL
YOU Switch-off your phone.
1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to switch on the phone.
Remember, do not let go the 3 press and hold keys until you see a formatting word screen show!
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory setting.
I HOPE THIS HELPS?
Mar 07, 2011 | Cell Phones
si want to change langauge to english
Feb 18, 2011 | i-mate Ultimate 8150 Smartphone
HOW DO I CHANGE TELEPHONE LANGUAGE TO ENGLISH?
2. Scroll through the menu options of your phone until you come to a settings option. Every cell phone has a different basic set up, but they all have "settings" areas, where the basic phone settings are located. One you have found the settings option, select it. The settings option will open a list of basic cell phone functions. Some cell phones have larger groups that are then broken further into smaller ones, and other phones have a bunch of small individual settings options.
3. Look for the option under settings that says system, display, display info, or language, and choose it. Whichever of these options your cell phone has, the outcome will be the same, so don't be discouraged if your cell phone has a slightly different set up than other cell phones.
4. Choose your desired cell phone language from the list and choose it, if your cell phone had a language option directly under settings. If not, then look for the language option under the system, display, or display/info options, and then choose your language from the list it provides
Feb 17, 2011 | Lands Phones
193 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
