Tip & How-To about Computers & Internet
Windows system always restart
Computer often restarts, can not enter windows.
Firstly check your ram.
If you can, do a test with the new ram it's better.
if not, make sure your use ram is fully functional.
Turn on your computer, if the problem is still the same.
Do a test on your power supply. make sure the power supply to do the test is 100% work or use the new.
Turn on your computer again, if the problem still occurs. unplug all cables connected to hard disks, cd / dvd rom, floppy and remove all the pci cards. now leave the connection to the power supply to the motherboard and the other connecting wayer suiz on / off (all the connections on the panel) if you are using a display card, left the display card in the slot and then turn on your computer.
Now look at the results. if still the same. This means you need to do tests on your processor and motherboard. but if your computer does not restart again stable, this means, most likely the problem comes from the hard disk.
Ok. now try to connect to your hard disk. problem occurs frequently restart
again right?
If so, you need to perform tests on your hard disk.
how to perform the test, if you have important data in the hard disk. I suggest you first Copy your data to another computer first. by connecting the hard disk into the computer that you want to use to make copies (if the type of hard disk pata / ideas, set the jumper to slave and connect to any idea that the cable has not been used in the computer you use, if no the cable idea, you can use a cable that is used for cd / dvd ram for a while) if your SATA hard disk, no need to set jumpers, just connect the sata cable and then just copy the data may be at work to do.
After completion of all copied data. The cover page, then klik2x on my computer icon. observe the hard disk drive for. (For example, now for the hard disk drive is e. Right-click on the drive and click format. If the page to format mungul. Tick box format for quick and clear the volume level and then click Start.
after the format, remove the hard disk and set the jumper to the original and put it on your computer. then for the window installation process you will be done as usual.
** (If your problem still occurs. My suggestion is that you must use a new hard disk or a 100% hard work and re-do the installation window, because the hard disk is damaged or has a bad sector will cause your system files are always auto restart due -file to boot normally have been damaged or lost due to bad sectors.) **
good luck ...
Contact me for further problems
Regards
multilinkent
Thank fixya
Computers & Internet Logo
Zebra TLP 3842 isn't printing
Step 1:Firstly, restart the computer and check the print queue.
After the computer restarts, double-click the printer icon in the lower right corner (the notification area) of the computer. The print queue opens.
If theprint jobs remain in the print queue,continue to the next step
Step 2: Run theFixitavailable in the link below:
Troubleshoot-printer-problems
http://windows.microsoft.com/en-US/windows-vista/Troubleshoot-printer-problems
Step 3: Make sure the printer is not paused or offline.
1. On the print queue menu bar, clickPrinter, and then look for thePause PrintingandUse Printer Offlineitems in the menu.
2. Make sure that there is no check mark next to either item. If a check mark displays next to either item, click to clear it.
Change-your-default-printer
http://windows.microsoft.com/en-us/windows-vista/Change-your-default-printer
Step 4:Run the fixit available in the link below to restart the Print Spooler service.
Fix printing problems by resetting the print spooler
http://support.microsoft.com/kb/2000007
You may try to add the printer locally and test
Add-or-remove-a-printer
http://windows.microsoft.com/en-us/windows-vista/Add-or-remove-a-printer
Mar 06, 2014 | Zebra TLP 3842 Thermal Label Printer
Compaq Presario V2000 PC Notebook: computer is slow...
try the following
1. click on start -> then choose run -> in the run window type temp and hit enter. A new window would come up. Select everything on the window and delete it.
2. click on start -> then choose run -> in the run window type %temp% and hit enter. A new window would come up. Select everything on the window and delete it.
3. click on start -> then choose run -> in the run window type prefetch and hit enter. A new window would come up. Select everything on the window and delete it.
4. You can also Uninstall apps that you don't use anymore. This can be done by going into the control panel and select Add/Remove Prorams. Scroll through and delete apps you no longer use. 5. Restart the machine.
I am sure that this would resolve the issue. In case it does not try this
click on start -> then choose run -> in the run window type prefetch and hit enter. A new window would come up. Select the tab Startup, and click the button Disable all. Click apply and then OK and restart your coputer.
This should help. in case not click start -> Accessiories -> system tools -> Disk Defagment
In case that also does not works, scan your computer for some viruses.
You may also look at the option of increasing the RAM / Memory on your computer
This should help
May 18, 2010 | HP Compaq Presario V2000 Notebook
there's a virus in my asus eee pc 2G surf and hard to connect to the internet. is it better to reformat it? How?
Check Two Solution:
Install Antivirus - Install new Symentec Antivirus Updated copy, and scan all Internet file, folder & Computer.
If problem presists - then format your Notbook or only your Notebook 'C' Drive
To format -
Windows XP installation:
1. Restart your notebook - and immedietly click on F2 key/Del button
2. Boot your computer from CD Drive
3. save your setting
4. it Running System File.
5. Then Create partition press Enter-(Delete previous partition)-press 'L'to delete your 'C' partition, If you want delete all partition, same delete like C drive.
6. Select 'C' Drive press enter to format partition choose option NTFS or Fat32, and Enter
7. It's running automatically then enter operation system windows CD Key and press enter
8. It will take time 30 to 35 min. Depending upon your RAM speed.
9. It will complete automatically and PC restart.
Feb 01, 2010 | ASUS Eee PC 2G Surf Notebook
213 people viewed this tip
David Payne
David Payne
