Tip & How-To about Computers & Internet
How to make bootable Windows USB
How many times did your Windows bootable cd get corrupted due to mis-handling?? it is surely a pain in the neck when such a thing happens. When you can choose to boot from a USB drive, why bother using CD's and DVD's. Here are a few simple steps that will help you to boot and install a Windows operating system (Vista and later), from your USB drive.
  • Plugin the USB drive and format it using device defaults option.
  • Press Windows Key + R (Run Option) and type in "%windir%\system32\compmgmt.msc /s". (without the quotes.)
  • Click on Disk management and right click on your USB drive and select "mark partition as active".
  • Copy setup files to your USB drive.
  • And VOILA u are ready to boot from your USB Drive.
If this method does not work use the lengthy method mentioned earlier.
For a detailed solution and explanation with screenshots please visit my blog.
Computers & Internet Logo
NTLDR is missing
Causes
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file..
  5. Corrupt boot sector / master boot record.
  6. Seriously corrupted version of Windows 2000 or Windows XP.
  7. Loose or Faulty IDE/EIDE hard disk drive cable.
  8. Failing to enable USB keyboard support in the BIOS.
Solutions
Many times this error is caused when the computer is attempting to boot from a non-bootable CD-ROM. First verify that no CD is in the computer, unless you are attempting to boot from a CD.
Nov 29, 2011 | HP Compaq 6710b Notebook
my dell dimension 2400 is not taking me to a log in screen due (0x00190203, 0x8237B670, 0xc0000102, 0x00000000.i turn the computer on and i click f2.i try changing around the setting because when i restart the computer, it says that the primary drive were not found.after i get out of the f2 selection, it goes to a windows did not start successfully.ive pressed ALL selections and its then loads the Windows xp screen for literally 3 seconds and goes back to the: a problem has been detected blah bah blah 0x00000024 thing.....need help what should i do? btw ive had this computer for a long time and ive put it away since this happen about 2 years ago and took it out 3 days ago trying to fix it. i dont want to call anyone to operate on it so im not sure what to do yet.and also, i want to know if theres anything i can download to a usb port to be abe to reboot or reinstall windows to the computer
In the Bios of the computer the F2 section that you are talking about what do you see under primary boot device?
You can always use a bootable operating system cd / dvd to boot your computer and reinstall the operating system.
It is possible that the HDD that you have on the desktop is corrupt but if you see the xp screen it is possible that the OS files are corrupt. you can use the recovery CD to fix the problem
Also try tapping F8 when the computer starts and choose Safe mode
if the computer starts then try to run the check disk command - chkdsk /r (for repair option)
The best chance you have to fix your computer is a bootable Operating system CD
Aug 18, 2011 | Computers & Internet
my toshiba L500 wont boot up when i turn it on it starts to load files then stops and tries to repair the problem but it does not
There are so many reasons boot up; i.e if system files corrupted by virus or hard disk index tables corruption or hdd partions corruption.
So as a initial trouble shooting try to do following things to resolve problem.
Option 1:
1. Power ON your computer and Press F8 key to have Windows boot menu option
2. Select "Safe Mode with Command Prompt" and Press Enter
3. When command prompt loaded then type follwing command and press enter
chkdsk /r c:
(If this command is not working in "safe mode with command prompt" then start computer with Bootable CD and Press "R" key when first time asked. It will open recovery console and type this "chkdsk /r "command again to repair disk.)
This command will scan your hdd and repair disk errors.
Option 2 :
To repair your windows without losing your data.
Start Computer with bootable CD
Press R when it is asked to press.
It will repair windows.
Note : Please read Status Bar and screen messages /nstructions carfully (while Booting computer thru Bootable CD)
Mar 28, 2010 | Toshiba Satellite L505ES5015 NoteBook
Unable to reinstall windows xp
try it again with the bootable floppy disk... if you have the option use fdisk /mbr and then format the computer and reinstall using the cd you have. the fdisk /mbr command will get rid of any virus residing in your master boot record.
May 24, 2009 | Microsoft Windows XP Home Edition
neck problem
Leaning into your computer or hunching over your workbench just makes its job more difficult. Poor posture certainly contributes to neck pain. Your neck contains bones, joints, tendons, ligaments, muscles and nerves, any of which can hurt. Neck pain also may come from regions near your neck, such as your jaw, head and shoulders. Conversely, problems in your neck can make other parts of your body hurt, such as your upper back, shoulders or arms.
Best Neck Pillow For Travel
Aug 27, 2008 | Conair Body Benefits Massaging Roll...
211 people viewed this tip
David Payne
David Payne
