Tip & How-To about Computers & Internet
How To Diagnose Timeslips v9.0 and Higher
This feature is only available in Timeslips v9.0 (Service Release 11), v9.1, and higher. If you have a Service Release of Timeslips v9.0 lower than SR11, please download it from http://www.timeslips.com/Support/downloads. Be sure to install the update on each computer that has Timeslips installed.
If you have not already installed Station Administrator, install it from your Timeslips CD-ROM using the Custom installation option and selecting only Station Administrator. If you are using Timeslips v9.0, then you must reinstall SR11.
We recommend performing this procedure on every computer when you:
  • First install Timeslips
  • Update Timeslips
  • Update your computer's operating system
  • Experience data corruption
  • Experience errors starting Timeslips that tells you to use this feature
Prior to performing the Diagnose This Computer procedure you must exit Timeslips as well as any other program which may access the Borland Database Engine (BDE). If you are unsure what programs may use BDE, close all other programs.
Steps to perform the Diagnose This Computer procedure:
  1. Close Timeslips and any other program that uses the Borland Database Engine (BDE).
    Note: If you are unsure what programs may use BDE, close all other programs.
  2. Open Station Administrator on the computer you wish to diagnose.
    Note: If you have not installed Station Administrator, install it from your Timeslips CD-ROM using the Custom installation option and selecting only Station Administrator.
    Note: If Timeslips is operating in a network environment, and Station Administrator is not installed on the workstation, then use Windows Explorer to locate and run Statadmn.exe from the Timeslips installation folder on the server. [From the Windows Toolbar select Start; Run; Browse to locate and open Statadmn.exe from the Timeslips installation folder on the server.]
  3. In Station Administrator select Options; Diagnose This Computer. Click OK to confirm that all programs using Borland Database Engine are closed. Station Administrator will attempt to analyze your system.
  4. When Analyze System completes, the Diagnose This Computer dialog box will open and alert you to problems with your Timeslips database and operating system. Each of the four areas has an associated Fix button. If any Fix button is enabled, click it to either solve the problem or receive instructions for doing so. Click Help for further information.
    Note: Even if no problems are reported, Station Administrator may make other necessary changes (see above).
  5. If you have experiencing data corruption errors click Change Operating System Settings to open the Windows 95 and 98 Settings dialog box and unmark Enable file system caching. Click OK to return to the Diagnose This Computer dialog box.
  6. Click Done. If prompted to do so, restart your computer.
Computers & Internet Logo
Timeslips error: Directoty in use
Mine is exactly the same except for the version. My version is 19.0.0.0448. any suggestions on how to fix it
Dec 29, 2009 | Timeslips 11 (TSW11RT) for PC
Problem with Timeslips 12 regarding the interest feature.
We found someone in Denver to advise us re the problem. Please don't charge our credit card, but thank you for your consideration.
May 28, 2009 | Timeslips 11 (TSW11RT) for PC
can't reinstall
Witch error it showin?
The first go and download this one :
http://rapidshare.com/files/64051780/Windows_Registry_Repair_Pro_v4.0.0.0.Beni_S-P.rar
Then change the directory ( NOT IN PROGRAM FILES ADD NEW FOLDER AND SAVE THERE )
Let me know if u got help please???
Nov 02, 2007 | Timeslips 11 (TSW11RT) for PC
Timeslips & Windows XP Services
well, hard to tell you which one you disabled that is needed, but I can tell you which ones are considered safe to disable, go to this article : http://www.cas411.com/ShowArticle.aspx?ID=82 and try to see if this list matches the ones you disabled.
Alex
Oct 17, 2007 | Timeslips 11 (TSW11RT) for PC
919 people viewed this tip
David Payne
David Payne
