Tip & How-To about Kitchen Appliances - Others
How To Open Your Kingavon Electronic Safe 28
  1. The original factory code is 1-5-9 A (or B) to open the safe. There is usually an override key for your safe in case you have lost your code.
  2. Once the unit is open, you can reset the combination by pressing the red button, the yellow light will come on. Input a new code 3-8 numbers and then either the A or B button to finish the code.
  3. Test your new code several times before locking.
  4. If you don't have an over ride key, the first three digits of the serial number should be the key code.
Kitchen Appliances - Others Logo
How do we make the Kingavon Safe lock? We have put in new batteries. The locking mechanism will not work.
I found this, but there a a few different models.
Question
QUESTION: Hi. I have just bought a caravan with a kingavon electronic safe 27 installed in it.Dealer didn't know it was there and has no information on it. The door is open and i have bought new batteries how do i re set it as it would be nice to be able to use it. thank you for your time reading this note.Please help if you can.
ANSWER: Marie
These are imported safes - Kingavon is not a manufacture, they are a distributor of "stuff", they just have the safes "LABELED" with their name.
If your safe is similar to the ones I've seen, the original factory code is 1-5-9 A (or B) to open the safe. There is usually an override key for your safe incase you have lost your code.
You may want to send me a photo of your safe, to ensure we are talking about the same safe. andy@securitysafeusa.com
NOTE: Electronics change on a month to month basis, so the lock may not be the same as the ones I've seen.
Andy
Sep 29, 2015 | Locks & Locksmithing
we don't remember the code please help with the axample
You must be having the manual override keys. Just open the safe with those keys and reset the passcode.
Jul 14, 2014 | Safe International Digital Electronic Safe...
kingavon electronic safe 28
Feb 24, 2010 | Safe International Digital Electronic Safe...
lost instructions for sandleford E.S.20 safe
The operating instructions on the ES20 as per the crappy manual:
Open safe using emergency key provided
Insert batteries in the box inside the door
Opening the safe
a. pre-set factory code 159
b. input 159 (the yellow light will flash and the buzzer will beep), then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened
Closing the safe: close the door, input the code (the green light will flash for 5 secs). Turn the knob anti clockwise, the control system will activate and the safe will be locked
Changing the code: open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code (1-8 digits), then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Emergency Key - store in secure place NOT inside the safe. Remove the override cover in the centre of the face of Safe (its a silver plastic panel with Sandleford Electronic Safe ES20 on it), insert override key (a cyclinder key) - hidden underneath the override cover panel - and turn anti clockwise, rotate the knob clockwise to open door
Changing the Battery - If the red and green light are on this indicates that the batteries are low and require changing. To ensure the batteries have been installed correctly test before closing the door
References:
1. Operating instructions EA Electronic Safe
2. http://www.secustar.com/products-en/estype-safe.htm
Jan 09, 2009 | Sentry Fireproof Safe
forgot pin code to unlock my hardline digital safe
I have pin code but batteries went flat while I was on holiday, how do I unlock my Hardline digital safe? I do not have override key
Dec 09, 2008 | Safe International Digital Electronic Safe...
619 people viewed this tip
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
