Tip & How-To about Samsung MM-A920 Cellular Phone
Resetting a "white-out screen" on your MM-A920.
We've had these phones for about 3 years and last week my wife's unit LCD screens(both the main screen and the smaller display on the front of the phone) stopped working completely. All you could see was a white screen on both sides of the phone when the unit was in use. We attempted all kinds of ways to reset the phone - in vain - and were getting resigned to buying a new unit.
As a last resort, I attempted to open up the unit to check for false contacts or other low hanging fruit. As you may know, the screws are covered by small black rubber caps in these phones - those caps make the screws "invisible".
Well... I took out the battery, and noticed a relatively large rubber cap. I used a needle to take it out, expecting to find a screw underneath - and... what I found was some sort of totally undocumented "reset switch". I just put the needle through the switch - which has a hole in the middle, as some old laptop "hard reboot" switches used to have - and the phone came back to full life after re-inserting the battery!
Hope this helps....!
Samsung MM-A920 Cellular Phone Logo
I've had my compaq presario cq61 for about 2-3 years. A while back it would occasionally have a kind of shaky/blinky screen but just in the past week it's like the screen has stopped working.
The problem may be due the graphics card or data cable or backlighting.
The data cable can be severed over time though opening and closing the display. This can be replaced.
The backlighting/inverter dies, some-times the windows desktop screen can be seen if one looks carefully. This can also be replaced.
Try connect your notebook to another computer's monitor via VGA or HDMI out.
If this works then the problem lies with your LCD screen.
Take care!
damnor01
Sep 11, 2012 | HEWLETT-PACKARD Compaq Presario CQ61412NR...
White screen 6500 slide I need help plz I've
Display can be Lcd,Flex connector,board connector,display IC etc.
If you already try at least 2-3 lcd, take another step of replacing flex connector 2-3 also, to make sure that the item you bought has no defect.
If this 2 parts didn't make it, check the board display terminal if its clean and corrosion free. resoldering each terminal may be helpful enough.
last option is replacing the display IC, it will serves as a fuse of it, a clystal square type that generate current to be able to display on screen.
Jun 28, 2011 | Nokia Lands Phones
Display screen unreadable. Removing battery
You have an (unfixable) LCD screen problem - the Liquid Crystal Display is dying (or broken by impact).
The best you can do (without a spare LCD screen and soldering/electronic repair skills) is hope that
there's a workaround that lets you use the phone without the LCD screen working.
Exploring a workaround: call the cordless from your cell phone, and see if you can answer by just using the keypad - if so, then the cordless works and it can be used until the whole phone dies (rather than just the LCD screen).
Most consumers just end up buying a new cordless about every year since these units take too much accidental abuse to last long.
If you decide to scrap the unit, save the battery for recycling at your nearest Home Depot.
They accept
old rechargeable batteries of any type - NiCad types used in cordless phones are especially toxic
(the (heavy metal) cadmium poisons spermatogenesis). Even better, save the battery for your
other GE 25932 5.8 GHz cordless phone - if you have a pair, then its mate's battery is old too.
Jan 02, 2011 | GE 25932 Cordless Phone
External display on pearl 8220 cracked
You can find blackberry flip 8230 and 8230 LCD screen replacements on ebay. Took a while but they are available now.
They are a little tricky to replace but not to hard.
Check out the guide I wrote for replacing the blackberry flip LCD display screen. There are also links to by the new pearl flip LCD screens
Blackberry Flip 8220 LCD screen Replacement Guide
Mar 17, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
3,658 people viewed this tip
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
