Tip & How-To about Heating & Cooling
HVAC or Air Conditioning System Noise
Ever wonder why your air conditioning system is so makes so much more noise than other systems that you see? Do you have to turn up the volume on the TV when the A/C starts up? Do you have to more to another spot in the house when you are on the phone because the air started to blow? I will offer some suggestions as to how you can make your air conditioning system quieter.
The main thing that you need to identify is that the noise is coming from the air moving through the vents. Then make sure that the vents are not broken or partly closed. If they are partially closed then you need to find out if they are just closed by mistake or to balance the system. Remember that if you close some of the vents then the air moved by the blower will have to be forced out of the other vents in the system. If there is too much air for the remaining vents to handle then they will become noisy. Sometimes there just simply is not enough space for the air to get out because there is a shortage of vents installed in the system. I have seen many systems that are this way because the contractor chose to skimp to cut costs on the installation.
Another place that many contractors chose to cut costs is in the balancing dampers that should be installed in the takeoffs from the main trunk lines of the ductwork. The absence of these dampers forces you to balance the air flow with the dampers in the floor or ceiling registers. This restriction at the point of entry into the room makes noise and is very annoying. Simply installing dampers at the correct location so that the branch lines can absorb the noise will solve that problem.
As you can see there are some things that can be done to eliminate noise that comes from your HVAC system. If your contractor tells you that there is nothing that can be done about your noisy system keep on looking till you find a competent contractor that can help you find the source of the problem and correct it. Your system does not have to wake the dead forcing you into all kinds of inconveniences because of the noise. With proper planning and the proper amount of supply and returns with dampers in the right locations, you can have a very quiet and comfortable system.
Heating & Cooling Logo
on my wall mount General Electric air condition compressor kicks on makes noise and then turns back off what could be the problem
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If your problem is still there we would suggest you seek professional help.
AC Repair Coral Springs
Apr 10, 2015 | General Electric Heating & Cooling
Heating/air conditioning ducts make to much noise.
depends if your main trunk line and your return duct are insulated on the inside or outside,if it is not on the inside then that would sound like a heavy rain every time it comes on.
Dec 02, 2012 | Heating & Cooling
I have a 2002 Pontica sunfire my air condition stopped working a couple of months ago it doesn't even put cold or heat air, it makes a weird nosie, i was wondering what it could be?
If the weird noise is like a coffee grinding machine, the a/c compressor is shot. If the noise goes away when you turn off the a/c, it confirms compressor trouble. If there is a screeching noise when you rev up the engine, it could be that the a/c belt has too much slack and is not turning over the compressor. Heat production and management has nothing to do with the a/c, it is a separate system,
Aug 14, 2010 | 2002 Pontiac Sunfire
whine noise
Does occur in certain conditions? Like when the Air Conditioning is on? Check the a/c compressor if so.
Jun 02, 2017 | 2001 Ford Mustang
Water cooling noise
Could be air in the system which you would need to bleed out. Either that or a faulty pump.
Sep 24, 2008 | Thermaltake Symphony mini Water Cooling...
833 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
