Tip & How-To about Heating & Cooling
Hiring a Heating or Air Conditioning Contractor
If you are looking for a contractor to do your heating or air conditioning job, what are the things that you should be looking for? It is easy to get caught up with a company's splashy ads or their slick sales talk. But do they have people doing the hands on work that are trained properly and can get the job of making your home comfortable done right?
The installation of any heating or air conditioning system is not a job that just anyone can do. Often many HVAC Companies make the mistake of hiring inexperienced people to install systems that they have no idea how they work or are designed to work. The company needs bodies to get the work done, so they go out and hire anyone who is willing to work for them. They then try to teach them the craft on the job. This lack of training will show up often years later after your warranty is up and you can do nothing about the faulty workmanship.
If you are getting quotes for work to be done in your home do not decide who will do your work simply by price. That is probably the worst criteria to use to award a job to a company. The company that will do the best job for you usually will not be the lowest bidder. They will have experienced people that they will have to pay a higher wage. The best job usually will require higher quality materials to do the job. This also will make the job cost more.
When you get your quotes try to compare materials that each one is using. Get detailed descriptions of the miscellaneous materials that will be used. Anyone can give you good quality appliances and then mess the job up with using bad materials to hookup the great appliance. Check on the experience of the people that will be installing your equipment.
Every time an installer does a job they will learn something more. A good installer will put that experience to good use and will learn better ways to install the equipment with every installation. Check references of installations that have been done by the crew that will be installing your job. If you are refused references then stop right there.
Getting your heating or air conditioning job installed correctly will take some time but it will be worth the extra effort. You may even end up with a different brand of equipment then you originally thought you would want. Just remember that the brand of equipment is not nearly as important as the quality of the workmanship that goes into the installation. It will be the installer that makes your job a great one that will perform trouble free for many years.
Heating & Cooling Logo
The heater in my excel blows cold air only . The dimist still works just no heat what should i look for?
There are several things that you can do about a heater blowing cold air, but if you keep running into problems then it might just be time to call in a heating repair company. If need be, here is a useful article on: HVAC installation cost, and how to get a fair price. How serious of an issue this is depends greatly on where you live. If you live in the north (Bozeman, MT, etc), then I'd recommend you have your furnace inspected annually to ensure that it is working properly. I'd also recommend that you install a backup means of heat...just in case. ASM has over 25 years of heating and air conditioning experience. If you have questions about a heater blowing cold air or any other HVAC related topic, try the ASM Air Conditioning and Heating Blog or if something your contractor is telling you seems expensive or doesn't sound quite right, consider using our Online Air Conditioning Consultation Service.
Jul 27, 2016 | Cars & Trucks
i can't find a blower wheel for my air conditionning ACP 102 GPW (WHIRLPOOL).and the part number for it. I need your help
Any heating and air supply house should have it. If not they can order it. Most heating and air supply houses only sell to licensed contractors. If you can't but it direct have a contractor buy it for you.
Sep 19, 2011 | Heating & Cooling
not working
HI, Troubleshooting an Aprilaire Humidifier
Aprilaire, a manufacturer of indoor air quality products including thermostats, air cleaners and dehumidifiers, also offers a line of whole house humidifiers. Installed in your existing heating and cooling system, humidity is produced by a supplied water source that flows over a water panel before being distributed throughout your air through the heating and cooling system. Issues you may need to troubleshoot with your Aprilaire humidifier include error messages and the unit producing too little or too much humidity.
Things You'll Need:
Replacement water panel
Turn down the control dial by one setting if condensation appears on your windows or walls.
Turn up the control dial by one setting if there is a lack of humidity, often indicated by dry skin or peeling wallpaper or paint.
Turn the control dial to "Test/Reset" if the humidifier does not run. Verify the heating and air conditioning unit blower is operating. If the heating and air conditioning unit is not operating or you are unable to resolve the issue contact a heating contractor.
Contact a heating contractor if you turn the control dial to "Off" and the humidifier continues to run.
Contact your Aprilaire dealer (see Resources) if you notice an error code on the display and the "Call Dealer for Service" light flashes.
Turn the control dial to "Off" and turn off the water supply if the yellow "Change Water Panel" light flashes. Lift the front panel off of the humidifier. Slide out the water panel. Insert a new water panel. Replace the front cover. Turn the control dial to "Test/Reset" until the "Humidifier On" light flashes. If you feel uncomfortable changing the water panel, contact a heating contractor.
Tips & Warnings
Purchase replacement water panels through your Aprilaire dealer or a heating contractor.
You can get parts from the link below:
arnoldservice.com/humidifier_parts.htm
Hope it helps.
Thanks for using fixya....
Nov 17, 2010 | Aprilaire 700 Humidifier
upstairs honeywell thermostat went out on 3/7 [no display]
FIRE THIS GUY!!!!
You have two systems.
These two systems should be wired totally independent of one another. I have the Pro series t/stat in my house. I love it.... I am a retired contractor I get stuff at cost. I paid about $130 for that t/stat. I understand he is in business to make money. But he should be fair enough that in the future you would want to call him back, Or even give him a nice referral. Alol this guy wants is your money. If the first guy admitted thatbhe did not have the expertice. He shouldn't be paid the experts price.
Call your city or county building inspectors office. Tell them that you would like a list of 4 or 5 reputable heating contractors in your area.
$275 should be fair for the nice t/stat and a fused transformer. Although a cheap t/stat would be fine.
Plus 75 bucks to pull upthe driveway. 60 -90 bucks labor to staighten things out. You should not have to pay for the romantic weekend away for the contractor and his wife.
GOOD LUCK!
Mar 08, 2009 | Honeywell Programmable Thermostat Heater
765 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
