Tip & How-To about Computers & Internet
How to convert AVI video to ipad for mac
IPad, is Apple's new tablet computer that released on January 27, 2010. It's realy cool to experience the web, email, photos and video with Wi-Fi iPad or Wi-Fi +3G iPad. However, iPad supported media formats are limited, such as MP4, MOV, H.264 Video files and MP3, AAC, WAV, AIFF audio. You can see the SPECS as follow:
1. H.264 video up to 720p, 30 frames per second, Main Profile level 3.1 with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in.m4v,.mp4, and.mov file formats;
2. MPEG-4 video, up to 2.5 Mbps, 640 by 480 pixels, 30 frames per second, Simple Profile with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in.m4v,.mp4, and.mov file formats;
3. Motion JPEG (M-JPEG) up to 35 Mbps, 1280 by 720 pixels, 30 frames per second, audio in ulaw, PCM stereo audio in.avi file format.
From above , we know that iPad only supports H.264 video and MPEG-4 video, So what should you do if you've got a lot of wonderful AVI videos and want to watch them on your iPad ? but do not worry a software called video to ipad converter software will help you solve this problem , following I will show you how to convert AVI video to ipad with easy steps.
Quick guide how to convert avi to ipad on mac compatible formats.
Step 1: Launch ipad converter for mac and import AVI Videos. For windows user: ipad video converter.
This AVI to iPad Converter software is a suite, including DVD to iPad Converter and iPad Video Converter, so you need to select "Video Converter" button to Convert AVI to iPad Video format. Click "Open Files" in the main interface to import your AVI videos into the program, you can also drag AVI videos into the program directly. This software supports batch conversion, so you can import multiple files at a time.
Tip: AVI to iPad Converter enables you to add different video formats and to get different output formats with only one conversion.
Step 2: Customize the AVI Videos for your iPad.
After you finish the setting of various effects, you can choose the output format from the "Profile" area, click the "..." to select iPad> iPad (*.mp4) and set the output folder by clicking the "Output" button.
Tips: If you don't want to use the default video and audio encoding settings, you can set the Video and Audio options, for example, Video Size, Video Bitrate, Audio Birate, Sample Rate, etc..
Step 3: If you make sure that everything is Ok, you can click the "Convert" button to Convert AVI to iPad.
Tips: After conversion, you can import the converted AVI video to iPad with iTunes. Just open iTunes and click "File" to load your MP4 video into iTunes library. Now for the next moment you can enjoy your AVI video on your ipad.
Computers & Internet Logo
How do Increase storage on my iPad
You can't enlarge the storage, you can only reduce the amount of items that you have on the iPad. Delete apps that you don't use and music you don't listen too. Transfer photos and videos to a computer.
Oct 03, 2015 | Apple iPad (16 GB) WiFi Tablet PC
disabled the ipad but have not got itune account or icloud how can enable it
You should do what this page has as 3rd option "Use recovery mode":
http://support.apple.com/kb/HT1212
Then it will be set back to as new, and you can give in a new pincode.
Also read this page before doing anything:
http://support.apple.com/kb/ht1808
To see if you can recover any Photos, Videos, Contacts & Notes try to scan the iPad directly with this tool while connected to the computer:
first install Wondershare Dr.Fone for iOS, then connect and try scanning the iPad directly. DO NOT REINSTALL ANY APPS YET !!
http://www.wondershare.net/disk-utility/ipad-recovery.html?gclid=Cj0KEQjwsJyfBRC729Oy5Pf26ekBEiQAYtd9QSJfMkH0yjzbSMulP0tV34yx5SEttc9X4G7JBQN7n1gaAjhK8P8HAQ
After recovering Photos, Videos, Contacts & Notes you will have to find and reinstall all your apps again, because they have been wiped by the recovery.
So now you know why it is wise to make a backup on a computer or on iCloud:
Install iTunes on the computer, then:
http://www.wikihow.com/Back-Up-an-iPad
Choose your backup method: iCloud or on the computer.
Let it run.
Good luck !!
Aug 10, 2014 | Apple iPad 32 GB WiFi Tablet PC
transfere photo from laptop to apple ipad
To transfer photo from laptop to iPad, follow this steps.
1. In the iPad management screen, click the "Photos" tab at the top.
2. Check the "Sync Photos" box at the top.
3. From the drop-down menu next to that, select the program or folder that contains your photo library.
4. Once all your settings are correct, click the "Apply" button at the bottom right corner of the iTunes window to sync again and add photos to your iPad.
5. Photos will consume space on your iPad, so keep that in mind as you select between syncing all photos and individual albums and videos.
May 09, 2012 | Apple iPad (16 GB) WiFi Tablet PC
195 people viewed this tip
David Payne
David Payne
