Tip & How-To about Intermatic Malibu 300W Power Pack Transformer ML300RTW
Power pack is not working
Open following links for information on power packs that include detailed troubleshoot steps, important links, trippers, and information about 5 year power pack warrany:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
Intermatic Malibu 300W Power Pack Transformer ML300RTW Logo
Where can I buy timer pins?
1) Copy following link for Intermatic replacement trippers, and tips for longer lasting power pack, 5-year warranty, and troubleshoot.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#trippers
2) If this is not your timer, Add comment Feb 2013 and describe timer in detail.
Feb 07, 2013 | Malibu ML200RT - Low Voltage Power Pack...
how do I set the timer with the two pins
The pin are probably trippers?
http://waterheatertimer.org/images/ML-Power-Pack-trippers-500.jpg
The trippers are red and black: black for ON and red for OFF.
Open following link for illustration of tripper install, and troubleshoot that walks through steps needed to operate and set timer, and keep timer working for many years.
Aug 10, 2011 | Intermatic Inc. ML121RT Malibu Low Voltage...
I moved the location my power pack timer ML121RT. It was working before now the clock is not turning. Lights will work manually so I have power through the power pack.
Open following link for troubleshooting steps and warranty information.
As a general rule, malfunctioning power pack clock is bad news because there are no repair parts or steps to take apart and fix. There are trippers, but if timer is not rotating, then trippers are not the problem.
However, you can buy cheap plug-in timer, set power pack to override, and plug power pack into cheap timer.
Power packs come with 5-year limited warranty.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 10, 2011 | Malibu Intermatic Inc. ML121RT Low...
Where can I purchase the plastic tripper switch
You posted under Intermatic or Malibu power packs:
For full information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips: Including order form and direct link for ML series black and red trippers
Nov 10, 2010 | Malibu ML200RT - Low Voltage Power Pack...
I have lost some of the little tripper clips. How do I get more replacement clips. Thanks for your help! Ron Leach
You posted under malibu/Intermatic power pack.
For more information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
If you have a different Intermatic timer, open following link:
If you do not have Intermatic timer, then add a comment with more information about the timer, including full description and what timer is connected to, and if this is plug-in or hard-wire timer.
Also check following link for other timers:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Jul 14, 2010 | Malibu ML88TL 88Watt Low Voltage Power...
4,140 people viewed this tip
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
