Tip & How-To about Garden
How to fix a recoil rope starter on lawn and garden equipment.
This tip is to help you if your power equipment starter rope broke and needs to be replaced.
Step One: Prepare the equipment to be worked on by disconnecting the spark plug wire from the spark plug. This will prevent accidental startups while working on the engine.
Make sure safety systems are in place. If this is a ride on unit make sure the brake is set and the battery is disconnected.
Step Two: Remove the Starter housing or blower housing. The starter itself will have at least three fastening points and may vary in shape depending on the machine. It is not recommended to remove any rivets if you come across them. Most machines with rivets are part of a larger housing that needs to be removed.
Step Three: Remove the leftover rope and inspect the starter spring. Once off of the machine you can remove any old rope and test the spring. the spring test is to spin or charge the spring as if the rope was being pulled out. As long as tension builds up in the spring you are ready to put a new rope in. If the spring does not build tension order a new spring from a dealer like www.arcolawn.com
Step Four: Charge the spring and install the rope. Charge the spring as mentioned above by rotating it as if the rope was being pulled. Once tight back the spring off one turn and put the rope into the starter through the housing and into the pulley. Tie a knot on either end ot the rope and then slowly let the rope into the starter (make sure the grip is between the two knots).
Step Five: Reinstall the starter housing on the machine and test.
I hope this helps. Joe
Garden Logo
How to replace starter Rope
William, could not find your exact model, the links below should help as a lot of blowers and string trimmers pull ropes are changed using similar method.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Quick and Easy Homelite Weed Wha cker Starter Pull Cord Replacement
How to fix string starter recoil on small outdoor power equipment like...
How to Install Pull Start Recoil for Backpack Blower
Apr 10, 2016 | Troy-Bilt Tb4bp 32cc 4-stroke Gas Powered...
How do I replace the pull starter cord
How do I replace Graeme, Check the attached links,instruction and videos on starter rope replacement. Good luck
String Trimmer Starter Repair
String Trimmer Recoil Starter Replacement Echo String Trimmer Repair Part...
How to Wind Up or Rewind Starter Pull Rope Recoil Spring on Yard Pro 130A...
Part 1 3 Changing the Recoil Rope on Craftsman Model 358 791030
Apr 01, 2016 | Garden
rewind starter cord
How To: Rewind a Recoil Rope (Fix a Broken ... - YouTube
? 2:52
https://www.youtube.com/watch?v=J0KJuqsJJ_k
Feb 16, 2012 - Uploaded by Champion Power Equipment
How To: Rewind a Recoil Rope (Fix a Broken Recoil Rope) .... Back off until rope hole in pulley lines up ...
How to Repair a Small Engine Recoil Starter - YouTube
? 4:49
https://www.youtube.com/watch?v=tmo6oYOJJ4U
Jul 15, 2011 - Uploaded by eReplacementParts.com
How to Repair a Small Engine Recoil Starter ... Would like to now use the pull cord on the mower but it won ...
Nov 28, 2015 | Garden
How do I replace the starter (pull) rope on a toro ccr2450 (model 38413)?
Although it looks like you simply un-bolt the recoil starter you need remove the whole blower (flywheel) housing as there are nuts on the back side.
  • Once the housing is off, remove the broken rope and prepare a length of rope to replace it base upon the old ropes length. Probably close to 6 feet.Don't forget to put the pull handle on the new rope.
  • Tighten the recoil pulley in the direction it normally turns as you pull the rope out until it stops.
  • Slowly back of up to one turn to align the hole in the pulley with the housing hole and hold it in that position while you insert the rope and try a sturdy knot.
  • Slowly let recoil assembly pull the rope back in and test that it is working properly before re-installing the housing.
  • Once you are satisfied that the recoil is working properly re-install the remaining covers.
Jan 15, 2015 | Toro Garden
The starter rope on my 14PZ push mower broke. How
The starter rope on my Masport push mower broke. How do I replace the rope and/or starter?
Sep 27, 2009 | Garden
243 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
