Tip & How-To about Video Game Consoles & Games
PSP ERROR CODE "8010850f"
How to fix error code "8010850f" on your PSP:
Error code "8010850f" sometimes appeared when you downloaded certain games on your PSP. It will requires you to activate the system to use the content and could only work when activated through PSN. Here are some tips and tricks on how to fix this error.
Option 1: Go to account management by signing in to PSN on your PSP. Once under account management go to activation/activate - games then activate the PSP.
Option 2: Connect your PSP to your PS3 using a USB. Then go to [Accountmanagement] - [activate/deactivate] - [PSP] - [games].
After you processed either of the 2 options you can now play your games with no interruption.
Hope it helps.
Video Game Consoles & Games Logo
psp error code 8010850f when trying to play demo games
From TIPS section:
Hope it helps.
Jun 18, 2011 | Sony PSP (Piano Black)
error code 8010850f
Assuming that you are using a PSP Go, then this error is caused by the fact that your device is not authorized to play your games anymore. This sometimes happens after a firmware update. In order to fix the problem, you must either attempt to sign in with the PSN account that you created when you purchased the device, or you must connect the PSP to the computer and use Sony's online PSP management page to reactivate the PSP. Go to: https://store.playstation.com/accounts/manage/cam_psp_activation_select.vm and then follow the on screen steps.
Feb 28, 2011 | Video Game Consoles & Games
I'm getting the error code 8010850f
Hi antoniodarri,
It seemslike you can't play games with your PSP. You also mentioned about the error "8010850f". Don't worry you can remove this error by applying the options below andthere's no need to delete anything or need of formatting your PSP.
Option 1: Go to account management by signing in to PSN on your PSP. Once underaccount management go to activation/activate - games then activate the PSP.
Option 2: Connect your PSP to your PS3 using a USB. Then go to accountmanagement - activate/deactivate - PSP - games.
After you processed either of the 2 options you can now play your games with nointerruption.
Hope it helps, Thank youfor using FixYa.
Feb 02, 2011 | Sony PlayStation Portable (PSP) Console
psp go i have an error code 8010850f it says i
If you are getting this error when trying to play games from memory stick i might have the solution for you.
1) Back up your data on memory stick to PC using usb cable.
2) Format your memory stick from PSP.
3) Copy game from your PS3 to your PSP using usb cable.
4) Copy game saves etc. from your PC back to your PSP.
5) Play your games on PSP.
Mar 21, 2010 | Sony PlayStation Portable (PSP) Console
psp i have an error code 8010850f it says i must activate system whats wrong how do i activate?
Hi vam7576,
With this type of error "8010850f", you really need to activate your PSP. You need to get rid of this error so you can play and use your PSP with no interruption. You can activate your PSP by doing either one of the options below. No files will be deleted during the process and no need to reformat your PSP.
How to remove error
"8010850f":
First Option:
Connect your PSP to your PS3 using a USB. Thengo to account management - activate/deactivate - PSP - games.
Hope it helps,
Thank you for using FixYa.
Best regards,
Reyjoshua07
Feb 27, 2010 | Sony PlayStation Portable (PSP) Console
2,872 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
