Tip & How-To about Garden
"Starts and Dies" Common engine problem?
The most common of questions for outdoor power equipment is "Why does my machine start and then die right away"
In a basic answer: Fuel delivery to the engine is not enough to maintain the running speed required of the machine.
Reformulated gasoline containing 10% ethanol has a shelf life of 60-90 days. After this point the ethanol absorbs enough moisture from the air and separates from the fuel that it clogs the passageways for fuel. A partial blockage will allow for the machine to start but not run very long on high speed. fuel system cleaning can fix this sometimes. Other times it is cheaper to purchase a new fuel system component.
A quick test on a carburetor type machine is to push the throttle shaft all the way to the closed position making the machine run slow. If the blockage is not too bad it will continue to run.
It is recommended to use a good stabilizer in your fuel while in storage up to 90 days. After 90 days dispose of the fuel and start fresh.
For exact details for cleaning your machine or obtaining parts visit a local dealer like www.arcolawn.com
Best wishes
barterjoe
Garden Logo
2001 Nissan start jerking on hway, died, putt putted home. Now starts dies out and backfires.
Make sure timing belt ( if equipped has not jumped/skipped teeth ). If ok suspect system running too lean ( not enough fuel ). You need to check for proper fuel pressure. Possible restricted fuel filter or defective fuel pump. Also there are a few sensors the vehicle relies on for fuel delivery that may have to be tested as well.
Jul 05, 2015 | Nissan Cars & Trucks
2001 Honda CRV, it will start & then suddenly dies going down road, after a little bit it will start back up & then dies again after you get going
why replace very expensive parts, guessing.?
so runs ok , dies runs ok, dies, ? is that it? hot, and cold?
did you do the 60k tune up yet, this repeats ever 60k miles.
that be first.
then see if you can save the STALL , with a fast right foot action.
yes, and has full power up any hill at that time, its not the fuel pump.
stalls have 4 major causes and 4 tests..
you can do the tests. or spend a fortune guessing, its your car and your bread (cash).
one very common cause is the EGR sticking open , the main EGR valve.
other:
1: 12vdc lost to the EFI system, the dash goes dead. lost elect. power.
2: lost compression , can happen hot engine only.
3: bad spark.
4: bad fueling.
there are simple tools and simple tests for each
do you want to test, or gue$$?
(EGR sticking or iSC sticking both can be clean before spending big cash guessing parts)
the fast foot answer, is the KEY FACTORY answer that
1 question and 1/2 the work stops. ive posted this many times.
and not one answer,
car starts to stall?
i slam right foot to floor.
engine, dies, or
is easy to save stall
or hard,
if i can save it , I IMMEDIATELY check for full engine power.
go that?
Feb 09, 2014 | Honda CRV Cars & Trucks
car wont start without a jump all lights on dash are on it starts then dies right away on 97 olds achieva
Seems you may have more than one problem. A few questions you must answer first. If you have to jump it to start it,then your battery is dead are you have a draw draining the battery. Now if it dies right away look at your security light and see if it is on. Probably your security system is thinking someone stole the battery and shuts the fuel system down. Change the battery and Google the reset security system on 1997 Olds Achieva and you probably be set to go
Sep 26, 2013 | 2000 Oldsmobile Intrigue
My truck died a few nights ago. Replaced the spark plugs, cleaned fuel filter, and now it starts up but then dies right away. It also sounds like there's air getting into the pump somehow. What could be the problem?
Have you checked the rate of fuel flow from your fuel pump to see if the issue is fuel delivery?
Can you keep the vehicle running by working the gas/throttle pedal?
If you can, then it's not a fuel pump issue, but may be an idle control valve issue.
Nov 10, 2012 | 2003 Chevrolet Tahoe
my 92 honda civic dx over heated. one of the hoses burst from the over heating. i fixed the hose. now the engine will start and it will pick up speed right away but hen it will die down. not shut off but if i am pressing the gas peddle the car does not seem to get power. then it will get power again after a few moments. i have only driven a short distance once the problem occurred and parked the car right away.
You need to have your engine temperature sensor tested, this tells the computer if the engine is hot or cold and allows the ECU to calibrate fuel delivery.
When the engine over heated this may have damaged this sensor.
Have it checked and let me know for further information.
Thanks
Jason
Aug 22, 2011 | 1992 Honda Accord
2,766 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
