Tip & How-To about Computers & Internet
Convert PDF to MS Word
The conversion may not be perfect, depending on factors such as the complexity of the layout, and whether you have the document's fonts on your system. For simple business documents, Acrobat's Save As command does a decent job of converting to Word.
  • To check or change the settings that Acrobat uses to convert PDF Content to Word format, open Preferences (choose Acrobat > or Edit > Preferences in Windows).
  • choose Convert from PDF from the list of Categories on the left side of the dialog box.
  • Then choose Microsoft Word Document from the Converting from PDF scrollable list.
  • The window at right shows you how Acrobat will handle the conversion, including whether it will include comments, preserve columns and down sample images.
  • To change these settings, click the Edit Settings button. (Alternatively, you can change these settings when you convert any given document by clicking the Settings button in the Save As dialog box.)
Computers & Internet Logo
arabic font nosupport
During a clean WinXP installation, the Arabic fonts are installed as part of what Microsoft calls
Complex Script fonts. (MS documentation.)
To add Arabic font support to WinXP follow these steps.
  1. Download fbarab.zip from this site.
  2. Extract the installation package from fbarab.zip with a decompression utility.
  3. Run fbarab.exe to install the Arabic keyboard layouts.
  4. Restart Windows.
  5. Load the keyboard layouts:
    1. Click on the Start button.
    2. Click on Control Panel.
      • The Control Panel is directly accessible in the standard Start menu but it is inside Settings in the classic Start menu.
    3. Click on "Date, Time, Language and Regional Options."
    4. Select the "Add other languages" task.
      • Or click on "Regional and Language Options" and select the Languages tab.
    5. Check the "Install files for complex script and right-to-left languages" option and click on the Apply button.
    6. Click Yes when you are asked to restart Windows.
    7. Go to "Add other languages" again and click on the Details button.
    8. Click on the Add button.
    9. Select Arabic in the drop-down list of input languages and select Arabic ASDF Eastern or Arabic ASDF Western in the drop-down list of keyboard layouts.
    10. Click OK as many times as you are prompted to and then close "Date, Time, Language and Regional Options."
For MS Office:
  2. Move the pointer over Microsoft Office Tools in Programs and click on Microsoft Office Language Settings.
  3. Select the Enabled Languages tab, check Arabic and click OK.
  4. Leave your preferred language as it is unless you really want to change it and click OK.
  5. Click OK.
I hope that helps.
Feb 20, 2011 | Microsoft Windows XP Professional
How do I add text to a scanned document?
Below instruction might be helpful to you.
With the PDF document open in Acrobat 7 Standard or Professional, choose File > Save As. In the Save As dialog box, choose Microsoft Word Document from the Format (Mac) or Type (Windows) pop-up menu. Then simply click the Save button, and open the document in Word for editing. The conversion may not be perfect, depending on factors such as the complexity of the layout, and whether you have the document's fonts on your system. For simple business documents, Acrobat's Save As command does a decent job of converting to Word.
Thank you.
Jul 31, 2010 | Online Double Conversion 1500VA 1050 Watt...
how to edit the text in pf
You will need to convert the PDF document to editable format. This software can help you do this: http://www.pdftodocconverterpro.com
Dec 08, 2009 | Avanquest Nitro PDF Professional
737 people viewed this tip
David Payne
David Payne
