Tip & How-To about Acronis Migrate Easy 7.0 (AME7)
How To Fix Your Unbootable Vista After Removing Acronis Software
  1. Insert your Windows Vista DVD and boot up to the DVD boot menu.
  2. Press OK to get past the language settings.
  3. Choose Repair Computer.
  4. Choose cancel if asked to run System Restore.
  5. At the menu, choose Command Prompt. This will put you on a command line in the WinRE.
  6. Enter "regedit" without the quotes.
  7. Highlight HKEY_LOCAL_MACHINE (HKLM) in the left pane.
  8. Go to the File menu and choose Load Hive.
  9. In the source box, navigate to the drive where Vista is installed (C: in my case). Drill down to C:\Windows\System32\Config. Choose the "System" file (with no extension). Hit OK.
  10. In the next window name the hive "Broken System" without the quotes.
  11. Hit the plus next to HKLM. You will see a key named " Broken System".
  12. Drill down to HKLM\Broken System\ControlSet001\Control\Class\{4D36E967-E325-11CE-BFC1-08002BE10318}.
  13. Look in the right pane for an Upper Filters line. If you see "snapman" without the quotes, you need to delete it.
  14. Only delete snapman by using the Modify on the Edit menu entry. Make sure you do not delete any other Upper Filters in the list.
  15. You should also check HKLM\Remote System\ControlSet001\Control\Class\{71A27CDD-812A-11D0-BEC7-08002BE2092F} for Upper Filter entries. If you see "snapman" remove it from there as well.
  16. Now unload the Remote System hive. Highlight it in the left pane. Go to the File menu and choose Unload Hive. This will save the changes in the Vista registry.
  17. Exit the command prompt and hit Restart.
Acronis Migrate Easy 7.0 (AME7) Logo
Toshiba satellite L300 will not boot up. error code 0xc00000e9
What you can do is attempt to repair the system using System Restore or startup repair. I would suggest trying startup repair first.
Method 1: Use the Windows Recovery Environment (WinRE) to run System Restore
1. Insert the Windows Vista or Windows 7 installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next
6. At the System Recovery Options Dialog Box, click on System Restore.
7. Follow the System Restore Wizard instruction as usual and choose the appropriate restore point.
8. Click Finish to restore the system.
Method 2: Startup Repair from the Windows Recovery Environment (WinRE)
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
6. At the System Recovery Options Dialog Box, click on Repair your computer.
7. (Click the operating system that you want to repair), and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
Hope this helps
Ray
Mar 07, 2011 | Computers & Internet
i have a dell inspiron 1545 and i need to format the hard drive how do i do it
Hi there are 2 Ways to Do it. You Choose .If this is the first time you are trying to do it on this 1545 if it was never formatted in the past use Method 1 if it was already formatted once in the past then use method 2 because method 1 wont be available. Method 2 is lengthy process.
Method 1 : Restore the computer's software to original condition.
Using Dell Factory Image Restore in Windows Vista
new_notice.jpg Notice: Restoring the original factory image erases ALL existing data. This includes files, folders, programs, drivers, E-mails, photos. Before performing a PC Restore, back up all personal files. If you do not back up your personal files, the data will be lost.
1 Turn on the computer.
2 As the computer starts, press on the keyboard until the Advanced Boot Options menu appears on the screen.
new_note.jpg Note: You must press before the Windows logo appears on the screen. If you press after the Windows logo appears on the screen, the Advanced Boot Options menu will not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
3 Press the on the keyboard to select Repair Your Computer on the Advanced Boot Options menu, and then press .
4 Specify the language settings that you want, and then click Next.
5 Log in as a user who has administrative credentials, and then click OK.
6 Click Dell Factory Image Restore.
7 In the Dell Factory Image Restore window, click Next.
8 Click to select the Yes, reformat hard drive and restore system software to factory condition check box.
9 Click Next.
The computer is restored to the default factory configuration.
10 When the restore operation is completed, click Finish to restart the computer.
The software is now installed as it was when the computer was first received.
__________________________________________________________________________________
Method 2: Reinstall the operating system from the OS Setup Disk. For Windows Vista
1 Insert the Windows Install DVD into the DVD drive, and then restart your computer. When the message Press any key to boot from the CD or DVD ... appears, press a key to continue booting to the DVD.
new_note.jpg Note: If the computer does not boot to DVD, follow these instructions. If it does boot to DVD ignore this note.
1 Power on the system and watch for the Dell logo to appear.
2 When the Dell logo appears, press the key to load the Boot Menu. If the menu does not appear, restart the system and tap several times at the Dell logo screen.
3 When the Boot Menu appears, highlight the CD/DVD drive (listed as "CDROM", "CD/DVD" or "CD/DVD/CD-RW") entry from the list and press .
2 After Vista Setup loads, confirm the Language, Time, Currency and Keyboard Method settings are correct then click Next.
3 On the Windows Vista Installation page, click Install Now.
4 Review the terms and click I accept the license terms to proceed.
5 On the Which type of installation do you want? window, click Custom (advanced).
6 On the Where do you want to install Windows window, make sure the largest Primary Partition is selected then click Next. If the Primary partition has 0GB free, there should be a separate line for Unallocated Space. Select this unallocated space and click Next.
new_note.jpg Note: Your computer will restart several times during installation.
7 When the Setup window appears, select a user name, password, and picture for your user account.
8 On the next couple of screens, use the default or recommended settings prompted and click Next until you see the Time & Date screen.
9 Click to select your time zone then click Next.
10 After the Thank You message appears, click Start.
If you need more details go to this page Source from Dell support site
How To Restore or Reinstall Microsoft® Windows® on a Dell™ Computer
Feb 04, 2011 | Computers & Internet
What to do if bootmanager fails?
hi frenofurs05,
Thank you for the post.
I suggest trying the following methods to troubleshoot the issue:
Method 1: Startup Repair from the Windows Recovery Environment (WinRE)
1. Insert the Windows Vista installation disc into the disc drive, and then start the computer.
7. Click the operating system that you want to repair, and then click Next.
Method 2: Rebuild BCD
1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
3. Select a language, a time, a currency, and a keyboard or another input method, and then click Next.
5. Click the operating system that you want to repair, and then click Next.
6. In the System Recovery Options dialog box, click Command Prompt.
7. Type Bootrec /RebuildBcd , and then press ENTER.
Method 3: Use the Windows Recovery Environment (WinRE) to run System Restore ============================================
Note:I just pasted this answer from other person cause its very long when i will wrote it and i think the better one than my explanation.
regards,
mastergani
Jan 03, 2011 | Toshiba Satellite L500 Series Notebook
I want 2 reset my entire dell d630 laptop How do I do this I don't have any of the passwords
Hey,
I hope when you say that you wish to reset the system you mean you need to go to the factory settings. If you wish to go to the factory settings and even if you do not remember the password, there is still a way to do it. But in order to do it you need to have the OS disc from Dell. You have one, you can perform the following steps. It works for Vista:
HOW TO RESTORE DELL LAPTOP TO FACTORY SETTINGS USING DELL OPERATING SYSTEM WINDOWS VISTA DVD
1. Insert the Dell Windows Vista DVD into the DVD drive, and then restart the computer. 2. During the startup process, repeatedly press <F12>. 3. In the Boot Device Menu, press the <Down Arrow> to select *Onboard or USB CD-ROM Drive, and then press <Enter>. If the Boot Device Menu does not appear, restart the computer. (You might not get Onboard or USB CD-rom Drive in that case if you get any option that says anything about CD or DVD, select that option) 4. When the Press any key to boot from CD or DVD screen appears, immediately press any key to start the computer from the Windows Vista DVD. For example, immediately press the <Spacebar> when the Press any key to boot from CD or DVD screen appears. If you do not press a key immediately, the computer may not start from the Windows Vista DVD to do image restore. Instead, the computer may try to start the currently-installed copy of Windows Vista operating system. If this situation occurs, restart the computer, and then repeat steps 2 and 3.
5. When Windows Vista starts from the Windows Vista DVD, other screens may appear during the startup process. If other screens appear, accept the default options, and then continue to the language settings screen.
6. On the language settings screen, click the appropriate language in the Language to install list, click the appropriate time and currency format in the Time and currency format list, click the appropriate keyboard layout to use in the Keyboard or input method list, and then click Next. 7. On the lower-left corner of the Install now screen, click Repair your computer.
8. If the Windows Vista Setup program detects any problems on the computer, click No when the program displays the following message:
Windows found problems with your computer's startup options.
Do you want to apply repairs and restart your computer? 9. In the System Recovery Options window, under Operating System, click Windows Vista (TM) Version, even if this entry is already selected, and then click Next to display the Choose a recovery tool window. 10. Click on Command Prompt 11. Type path d:\windows;d:\windows\system32 and press <ENTER> key 12. Type d: and press <ENTER> key 13. Type cd tools and press <ENTER> key 14. Type PCRestore and press the <ENTER> key and Dell Factory Image Restore window will appear 15. Click on Next and Confirm Data Deletion dialog will appear 16.Place a check mark beside "Yes, reformat hard drive and restore system software to factory condition" for the final confirmation & click on Next when ready The restoration process takes approximately 10 to 15 minutes; the format bar will run back and forth (See Image 17. Click Finish to reboot system
Jun 25, 2009 | Dell Latitude D600 Notebook
black screen on laptop, will not boot in safe or normal. no back up disk, tried f11 sys recov did not work
2. Press a key when the message indicating "Press any key to boot from CD or DVD …". appears.
May 15, 2009 | Compaq Armada E500 Notebook
588 people viewed this tip
Top Acronis Computers & Internet Experts
richie46
tuffbird72
InHouseTeq
Are you an Acronis Computer and Internet Expert? Answer questions, earn points and help others
