Tip & How-To about Computers & Internet
Control your fonts
Reading a document created in another machine and do not need a font to view it properly? Check your font substitution - select Tools >Options and click on the compatibility Font Substitution button.
Computers & Internet Logo
change default font
Microsoft Outlook is an email application that can be used as a stand-alone program or with Microsoft Exchange Server.
Many companies and businesses choose Outlook as their preferred email client.
Features of the program include the ability to manage a calendar, contact list, task list and journal.
Outlook contains folders for components such as the Inbox and Calendar.
These items have a view assigned to them determining the colors, fonts, fields and many more settings that control how the items appear in each folder.
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
New views can be created and assigned to folders to change the way the folders are viewed.
Click on "View" from the top menu, and select "Current View."
Select "Define Views," and click "New."
Type a name in the "Name of new view" field.
Select the view type that you would like from the "Type of view" box.
Select the option of where you want the view to be available under "Can be used on," and click "OK."
Select the options you wish to use in the "Customize View: view name" box, and click "OK."
Click "Apply View" to begin using the new view.
http://office.microsoft.com/en-us/outlook/HA101209011033.aspx?pid=CH100777471033
Nov 23, 2013 | Computers & Internet
i ve lost all my fonts in corel. I tried to install a new font and all the fonts i have disapeared.
Most probably the problem is caused by the font list options.
Go to Text -> Font List Options or Tools -> Options -> Workspace -> Text -> Fonts
Once you're there play around with these options. The solution most probable to work is disabling "Show document fonts only"
Apr 14, 2010 | Corel DRAW Graphics Suite 12 for PC
unable to leave comments in adobe 7 documents since upgrade
Choose View > Toolbars > Comment & Markup.
To add or remove tools for this toolbar, choose Tools > Customize Toolbars.
  • Select the tool you want to use (but don’t use it yet).
  • Choose View > Toolbars > Properties Bar.
  • Select Keep Tool Selected.
Aug 05, 2009 | Computers & Internet
how do i permanently change font type and size to be default when writing email inaol desktop?
If you want to change the default HTML font size for outgoing e-mails:
  1. Right click on the Desktop > Properties > Appearance.
  2. Select "Message Box" in the Item drop down box > change the font.
If you want to change the default HTML font size for incoming e-mails (Using IE 5.5):
  1. Open Internet Explorer > Tools > Internet Options > Accessibility.
  2. Check Ignore font styles and Ignore font sizes.
  3. Adjust the font style by editing the selections under the Fonts tab under Internet Options.
You can also create a style sheet (cascading style sheet) and use it as the default for all of your web pages. This option is accessible through the Tools > Internet Options > Accessibility menu.
Jul 23, 2009 | Computers & Internet
If I write a document on microsoft works word processor and send it to someone with microsoft word, will they be able to read it on microsoft word?
PECIFYING FILE COMPATIBILITY
As different versions of Word have been released over the years, there
are noticeable differences in the way text layout and formatting
appear. Sometimes it’s necessary to make changes to an existing
document so that it emulates the formatting of a previous version of
Word. Having this ability makes viewing these types of documents
easier. The changes you make aren’t permanent, so you can change things
back to the old display if you need to.
1. Open the document.
2. Go to Tools | Options | Compatibility.
3. Click on the Font Substitution button to substitute non-supported
fonts with supported ones, and click OK.
4. Choose the version of Word you want to emulate from the Recommended
Options For drop-down list.
5. Enable the appropriate check boxes in the Options list to select any
additional desired display aspects.
6. Click OK.
Today we get to deal with compatibility problems between Office 2007and previous versions. Office 2007 is supposed to be able to openstandard 2003 and previous files, but you still have font problemsoccasionally. If you’re using an older version of Office, you candownload the Compatibility Pack which is supposed to make OpenXML documents work in Office 2003, but it’s kind of a hit and miss affair.
Sep 16, 2008 | Microsoft Computers & Internet
159 people viewed this tip
David Payne
David Payne
