Tip & How-To about Computers & Internet
Stay connected when you?ve logged off
When you log out, then make your Internet connection. However, you can keep it open for the next user. To do this, simply navigate to HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \registry.From CurrentVersion \ Winlogon here, you must right-click the right pane and select New String Value. thenext step is to name the value KeepRasConnections and finally, double-click
the new entry and set its value to 1
Computers & Internet Logo
not able to go online
have you been online with this computer before?
or
Are you setting up for the first time?
Once you have an Internet Service Provider ,ISP,
you just need a modem and phone line access,
plug modem into phone socket and then into the computer,
My example modem is.........
Speed Touch 5x6v6 - Broadband Modem
log on to the modem using Internet Explorer Bar
Type 192.168.254
this will open the modems log on menu
then enter user name and password
its factory default is
user ADMIN
password ADMIN or 1234
once open there are some menu options on the main page
Speed Touch,
Broadband Connection,
Toolbox,
Home Network,
to add new user and password,
go to toolbox,
user management,
add new user
add password,(write down username and password)
change default user
save and test
should have a green tick next to new default user now
selecting broadband ... shows both your,
dsl connection and internet connection status,
with a green tick next to each heading.
Home network will show you...
all devices connected to this modems network ie
the other computers and printers etc,
connected on your network.
In network ,select your computer in the menu tree,
select configure
this give you a menu to add info about your computer
ie name info, comupters ip address,
access to the local intranet or the internet
Now lets connect to the internet
select Broadband from fornt page
menu will open and display
DSL & Internet Connections
here we test functionality.on? or off?
Now we go to your computer,
start my network connection
run wizard in my network places
select new connection
follow prompts to the end.
open internet explorer
if web page opens then we are done and finished,
open tools and internet options,
connections and then lan settings
select automatically detect
Apply then close
Test webpage again,
when ok shut down and restart,
to save the computers new settings ,
Test again with internet explorrer.
if no connections run wizard again,
Hope this Helps,Cheers Misterdj
Apr 18, 2010 | IBM ThinkPad T30 2366 Notebook
need help getting my internet to work for cricket i flashed my htc from spirnt to cricket but no picture mail or internet
this is assuming that you have already loaded the arcsoft mms program onto your phone.. if not you will need to do some searching to find it... but since you said you were having problems getting it to download pictures,, im going to assume you have it on there.. so here you go...
go to Start/settings/connections/connections/advanced/select networks
once you get in there then click on add new modem connection and name it Cricket WAP and the modem should be Cellular Line and press next
on the next screen put #777 and click next
enter your User Name is yournumberwithareacode@mycricket.com and passwork is cricket and click finish
now go to proxy settings and check both boxes and write wap.mycricket.com on proxy server
now go to advance and write wap.mycricket.com on the server and 8080 in the port(do it in all 4) now click ok until you go back to network management
now on the second one click new and name it Cricket mms and celular line and click next
do step 5 & 6 again.
now you are done with the connections settings
For the next step you will need a registry editor
You can find phm regedit for free or use resco registry editor from resco explorer pack,, they have a demo
open it and go to Hkey Local Machine/software/arcsoft mms ua/config/mm1/wspheader
look for these strings and make sure they say this,, if not then edit them to be like this....
Accept Application/vnd.wap.multipart.related
Accept-Language en
User-Agent Arcsoft/MMSUA/v3.0
X-Cricket-MDN your phone number(you might have to replace sprint to Cricket)
if you missing some of them, go to edit/ new string
and if there are other stuff on there besides those 4, delete them
Now go back to Hkey Local Machine/software/arcsoft mms ua/config/UI
find EnableServerEdit
and change it from 0 to 1
now you need to soft reset your phone...
now go to your messages and click menu/MMS configuration and then click server and click add new,, add new or if you already have one called verizon or something,, just click it and click edit...
you need to change/input these settings into it
Server Name Cricket
Gateway leave blank
Port Number 8080
Server address http://mms.mycricket.com/servlets/mms
Connect Via Cricket MMS
Sending limit (your choice)
Wap version Wap 2.0
Mine is working great.
Good Luck
Dec 04, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
yahoo messenger keep loging me off
after logging in ym, do you go to chatrooms? there are so-called yahoo booters that boots your ym when you join a certain chatroom.
Make sure messenger is off, then go to regedit then open up HKEY CURRENT USER then open up SOFTWARE then open up MICROSOFT then open up WINDOWS then open up CURRENT VERSION then click on Internet Settings but dont open it just click on it then go half way down the list to find PROXY ENABLE,PROXY SERVER,PROXY OVERRIDE then click on PROXY ENABLE click modify binary and change from 0x00000000 (1) to 0x00000000 (0) then delete PROXY SERVER and PROXY OVERRIDE and there you go sign into messenger this has worked perfect for me hope it does for you.
or
It's either one of the two:
- Yahoo! servers are down for maintenance, the only fix would be to wait.
- Your connection preferences are wrong:
Messenger tab just above where you sign in and then click the Connection Preference option
Oct 18, 2008 | Yahoo Messenger
158 people viewed this tip
David Payne
David Payne
