Tip & How-To about Computers & Internet
Increase BSNL(India) Broadband Internet Speed
With these steps you can increase the speed of your BSNL broadband
1 First of all make sure you are logged in as Administrator.
2 Go to Start >> Run >> gpedit.msc , Press OK.
3 Then go to Computer Configuration >> Administrative Templates >> Network>> QOS packet Scheduler.
4 On the right it will give you the option of Limit Reservable bandwidth, open
and and select Enabled, and change the value from 20 to O.
Computers & Internet Logo
How to cofigure my Dlink 502T modem for BSNL connection at chennai
If you want to connect and disconnect at your ease, the following steps will guide you through setting up a internet connection in windows using username and password whenever you connect.
Have a good time...
Step 1: Initial LAN Configuration First connect all the equipments to your PC. Details about this is probably given on the manual
Now on windows go to control panel -> Network Connections
Select “Local Area Connection” and right click it . . . Select Properties
Select TCP/IP in that box ->properties
Enter the details as follows
Set IP Address As 192.168.1.29 Subnet Mask As 255.255.255.0 Default Gateway As 192.168.1.1 Preferred DNS 208.67.222.222 Alternate DNS 208.67.222.220
Save settings and restart the computer.
Step 2: Settings for Modem Make sure the Power LED, Link LED and USB/LAN LED are on/blinking Open your browser (preferably Internet Explorer ) and goto http://192.168.1.1/ Input as follows USERNAME : admin PASSOWRD : admin
Now goto Setup Tab then click on new connection (left side navigation frame/panel)
Now fill the details as follows Name : BSNL
Type : bridge
Sharing : disable
VLAN ID : 0
Priority Bits : 0 Encapsulation : LLC Select LAN : LAN GROUP 1 PVC : new VPI : 0 VCI : 35 Leave all others at default values Then click apply The go to TOOLS tab Click “system command” (left hand side) Click “save all”
Apply and restart the modem.
Step 3: Setting up Internet Connection Dailer in windows Now goto Control Panel->Network Connections Create New connection (and a wizard will pop up)
Click Next
Connect to Internet(Select the radio button and click next)
Setup My connection Manually(select it and click next)
Connect using a broadband connection that requires a user name and password (select it and click next)
ISP name (type something, anything and click next)
Type in the User name and password given to you from BSNL in the specified columns (and click next)
If you want to add a shortcut of connection to desktop, check that square box and click finish.
Double Click the Icon in the desktop to connect to the BSNL Dataone broadband connection, and either double click the same icon or right click the system tray icon to disconnect from BSNL Dataone broadband connection.
Hope this will help you.
Feb 11, 2010 | D-Link Computers & Internet
how to increase my internet speed?
You click this link
Its contains the tips about the increase the internet speed and You can check the speed in the site ipdetails
Aug 26, 2009 | Lenovo IdeaPad Y530 Laptop
slow net speed
change to wired broadband , airtel should be a good choice.
Mar 21, 2009 | Computers & Internet
gprs settings
For BSNL South prepaid or post paid use following settings:
Start/ Settings/ Connections /GPRS
Connects to : Internet
Access point: gprssouth.cellone.in
Leave other items blank.
Start/ Settings/ Connections /Proxy
Donot creat any proxy
You donot require any thing else. GPRS will work on your mobile and also in Internet share. Internet share works with cable and bluetooth. Browse on mobile or laptop !!!
9448834529
Dec 10, 2007 | HTC Touch P3450 Smartphone
164 people viewed this tip
David Payne
David Payne
