Tip & How-To about Radio Shack Accurian APD-3955
Fixed the problem
I just reset the device to the factory settings and now it works.
Radio Shack Accurian APD-3955 Logo
how to hard reset cherry mobile superion radar c
Hi Juramil,
Try this:
1. Open your device's Settings. The Settings app can have varying icons depending upon on your specific device, and may be also be found within the App Tray or by pushing the phone's dedicated menu button.
2. Find your Factory Reset option. Depending on your device, the "Factory data reset" feature may be located in one of two sections within the Settings app:
Select the "Privacy" settings, and scroll down to "Factory reset"
Select the "Backup and reset" settings, and scroll down to "Factory reset"
3. Tap "Reset device" to delete all data and restore your device's factory settings. The accounts that you are signed into will be displayed on the screen. By default, all of your phone's internal storage will be wiped.
If you want to erase all of the data on your phone's SD card as well, check the box at the bottom of the screen.
4. Confirm the process by selecting "Erase everything". This will delete all data and restore back to your device's factory settings. Your phone will be as if it just came out of the box.
Jun 02, 2017 | Cell Phones
Letter 'B' doesn't work on my keyboard!!!!!
You could try re-calibration, or reset the device, or restore device factory settings as per the below 3 options. There is also a link at the bottom to a user guide. If that doesn't work, you probably have a faulty touch screen, in that case return the device to the place of purchase for warranty repair/replacement:
Q: G-SENSOR is not responding.
A: You should calibrate your device using 'Settings' / 'Display' or Gravity Calibration App (optional).
Q: My GOCLEVER tablet does not react well, it is freezing, works much slower than normal or does not respond at all.
A: We recommend to restart your device using turn on/off button (pressing 3-4 sec) or reset button (with a pointed object).
Q: How do I restore factory settings?
A: You should use 'Factory reset' function available in the 'Settings' App. The factory reset will help if your application causes the inappropriate operation of your device. Note, that all your files will be lost, so we suggest to copy them to another device (pendrive, PC etc).
http://1palladium.com.ua/load.php?f=goclever-terra-101.pdf
Oct 13, 2014 | Tablets & eReaders
securety code eror
check this one
Master Code Generator will Instantly generate your Nokia's Master security code.
This service can be used if you need to reset your Security Code.
Your IMEI: 356924034968264 --
Your Nokia Master Code: 2401254345
or this one
Nokia 5000 hard reset
You can format your Nokia 5000 device by typing: * + 3 + call + Power on. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
If it is not working try this code:
You can format your device by typing *#7370# in standby mode. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
Some Nokia phone can be reset via this menu option
Press menu button or enter Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore > YESRestore factory settings
To restore the phone back to factory conditions, select Menu > Settings > Rest. factory sett. and from the following options:
Restore settings only - to reset all preference settings without deleting any personal data
Restore all - to reset all preference settings and delete all personal data, such as contacts, messages, media files and activation keys
IMPORTANT!
Formatting the device will permanently erase all user data and settings as well as add-on applications and operator specific settings
goodluck
Apr 21, 2014 | Nokia 5000 Cellular Phone
nokia format nokia 5000d
Nokia 5000d hard reset
IMPORTANT!
goodluck
Apr 21, 2014 | Nokia 3110 Cellular Phone
how can i reset my sph-m830galexy rush if vol toggle dosnt work
Open the application list and select
Settings - Back up and reset- Factory data reset - Reset device - Delete all.
But first - back up your important data before you perform a factory reset of the device as you will lose everything.
Sep 11, 2013 | Samsung Cell Phones
537 people viewed this tip
Top Radio Shack Televison & Video Experts
Computer Repairing
Computer Repairing
xxxxxx xxx
Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
