Tip & How-To about Cell Phones
How To Reset Your Samsung Monte S5620
Soft Reset
  1. Pull the battery out and reinsert it.
  2. Turn the phone on.
Hard Reset
Note all your data on the memory card will be erased during this operation.
  1. To reset your Samsung Monte, tap on the Menu button>Settings
  2. Scroll down to the "Reset settings" option
  3. Choose the items you want to reset: Phone profiles, Display and Light, Phone Settings, or select all the 3 items.
  4. Tap on Reset.
  5. You will be prompted to enter a password.
  6. Based on your Operator it can be: 00000 or 1234
  7. Press Confirm.
Cell Phones Logo
how do i factory reset a coby kyros mid8024?
There are two methods of reset Coby Kyros MID8024:
1. Soft Reset
2. Hard Reset
Steps for Soft Reset:
  • Take out the battery.
  • Reinsert the battery.
  • Press and hold the power button for 10 seconds.
That's soft reset. If your device doesn't load after this, try hard reset.
Steps for Hard Reset:
  • Switch off the device.
  • Press and hold Volume Up + Home Button + Power Key.
  • After 2-3 seconds, release the Power Key.
  • You will enter boot screen, Select Wipe Data / Factory Reset.
  • Select Yes.
This will delete all the files including apps, personal data stored in phone memory. Don't worry it doesn't wipe off the SD Card so you should make a backup of your files stored in phone memory.
Apr 15, 2015 | Coby kyros Tablets & eReaders
Can reset my phone because i forgot my security code
1.- Basic Reset or Soft Reset This option does not erase data (photos, videos, documents) or applications from
a third party. Key Code *#7780# (click this combination of keys on the
keyboard in the mobile)
2.- Total Reset or Hard Reset This option restores the original operating system from the ROM.
Formats the C: partition and deletes all data including the memory
card. Key Code *#7370# (click this combination of keys on the keyboard
in the mobile)
Important: To proceed to reset, the battery must be full and the
mobile device connected to the charger. If during the course of reset,
the mobile stop receiving electricity it can ruin the internal flash
memory of the mobile device and stop function.
Try first Soft reset, so you do not need to backup your data, in case there is still forgotten security code, then backup your data and use the Hard Reset
Jul 06, 2011 | Nokia 5130 Cellular Phone
phone freeze
Turn the phone on.
If this keeps happening, you may need to reset your phone, or bring it in for repairs.
Here is how to reset your phone:
  4. Tap on Reset.
  5. You will be prompted to enter a Password
  7. Press Confirm.
Note that, all your data on the memory card will be erased during this operation.
Feb 16, 2011 | Samsung S5620 Cell Phone
Can you fix my low on memory palm centro. It erased all of my photos and won't take new ones. It says momory is too low. Can you fix?
hi,
you have to reset your phone in order to fix that..but you have to save all your important data before you do the reset...here is how..
Performing a soft reset is similar to restarting a computer. If your Centro device is not responding or you're having trouble synchronizing with your computer, a soft reset may
help. All your information is retained when you perform a soft reset.
1. Remove the battery from your device, and then reinsert it.
Note: The reset begins when you insert the battery and ends when the
Date & Time Preferences screen appears.
2. Select Done.
Replacing the Battery
Your Centro device comes with a replaceable battery. Be sure to use a battery that is approved by Sprint and that is compatible with your device. Failure to use the proper
battery may result in personal injury or product damage, and it voids your device warranty.
1. Press Power/End palm_centro_hard_reset_soft_reset_2.jpg to turn off the screen.
2. Gently press down on the Battery Door, and then slide the door downward to remove it from your device.
3. Place a finger in the notch next to the battery and lift the battery up at a 45-degree angle to remove it from the compartment.
4. Align the metal contacts on the new battery with the contacts inside the battery compartment.
5. Insert the new battery into the compartment at a 45-degree angle, pressing it into place. Slide the battery door onto the back of the device until it clicks into place.
6. Connect your device to the charger or sync cable.
7. Wait for your device to turn on, and then enable the network time or set the date and time when prompted.
System Reset
A system reset, also called a safe or warm reset, can be useful if your device loops or freezes during a soft reset. Performing a system reset allows you to get out of the loop and restores limited functionality to your device in order to uninstall a third-party application that's causing the problem. Note that after a system reset, you must perform a soft reset to restore full functionality, including the wireless features, to your device.
1. Remove the battery from your device.
2. Press and hold Up palm_centro_hard_reset_soft_reset_3.jpg on the 5-way palm_centro_hard_reset_soft_reset_4.jpg while reinserting the battery.
3. When Date & Time Preferences appears, release Up palm_centro_hard_reset_soft_reset_3.jpg
4. Delete the third-party application that you suspect is causing the problem.
5. Perform a soft reset. (The wireless features of your device are not available until you complete this step.)
ard Reset
A hard reset erases all information and third-party software on your Centro device. Never perform a hard reset without first trying a soft reset and a system reset. You can restore previously synchronized information the next time you synchronize.
A hard reset can tell you if a problem stems from your Centro device or from an application installed on it. If you do not experience the problem after you perform a hard reset, the problem is related to software you installed.
Important: If you set a password on your device, performing a hard reset reformats your device (the message "Reformatting in progress" is displayed). This is a more severe form of a hard reset, which removes all your information and restores your formats, preferences, and other settings to the factory default settings.
Note: Some third-party applications do not create a backup on your computer when you synchronize. If you perform a hard reset, you may lose data in these applications and you need to reinstall these applications after the hard reset. Please contact the developer to find out which information is backed up during synchronization.
i hope it will help you..thanks for trusting fixya
Jan 31, 2011 | AT&T Palm Centro Cell Phone - White
how to reseta nokia n95 memory
you can do a soft reset that will reset the memory for your nokia n95 . Here are a couple of codes to soft/hard reset/format a Nokia N95 mobile device: Soft reset code *#7370# Hard reset code *#7780# If the hard format code mentioned aboive does not work, try the following manual method to hard reset/format Nokia N95: + Turn off the mobile device. + Press and Hold the following three buttons: the green Call Answer button, the ?*? button, and the number ?3′ button. + While holding these buttons, turn on the phone and keep holding the keys untill the mobile phone restarts and prompts you to enter details. (note a hard reset will erase all data that is not saved to a sim or card) a soft reset only resets the memory and the phone. it will not erase your data that you saved
Nov 11, 2009 | Nokia N95 Cellular Phone
1,177 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
