Tip & How-To about Computers & Internet
How to Protect PC from Overheating?
Laptop over heating which is also known as Thermal Overload.This is mainly due to excess usage of CPU(More than 60%) for a long time.
To check CPU usage Right click on Task Bar>Select Start Task Manager>Performance.
or
Shortcut Ctrl+Shift+Esc
If your CPU usage is more than 50% you need to close some applications which are using 20++% CPU.
To check application which are using 20++% CPU
Right click on Task Bar>Select Start Task Manager> Processes
Search in this dialog box for programs which are using 30++% CPU
Have a look.......
You need to close this application to prevent PC from over heating.Actually %age usage indicates load to CPU by the application.If load is to much CPU is to processes at faster speed which in turn increases temperature of CPU.
To close the program select the program,and select End Process.
If didn't found any program using 30++% CPU in this dialog box.
Select Show process from all users. and search in this dialog box and close the program.
Caution:some times your system also uses 30++% CPU inn some processes like anti virus scanning,at this if you closed the program your PC may shutdown.At this time you need to restart the PC.
This usually happens for out dated anti virus or incompatible programs.
There are some other factors like Graphics Properties and Graphic Memory,Display size, Processor type,etc.At this time its better top use a cooling pad.
Some program like camera drivers,Simulation softwares,games uses 50+% CPU.This is common these programs need to process large amount of data at short interval time which increases CPU usage but this is normal.
The processors properties are tested at 140*c so no need to worry.If the CPU exceeds the limited temperature PC will shuts down automatically,and after cooling you need to start the PC.
Thank you...:)
ANY SUGGESTIONS...?
Computers & Internet Logo
my acer aspire one netbook is freezing whenever i stay on it for more then an hour,my laptop has no virus, i think it is the cpu usage..how do i fix this?
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Dec 06, 2012 | Acer Aspire One A150-1006 Notebook
i bought my new Sony Vaio VPCEH last 2 weeks ago,. dual core, 2.3ghz, 4gb ram.. what i wondered is why my cpu almost overload all the time even i just use firefox, or explorer (opening folders ) or so
The CPU is runnimg with a useage of 45-60% as soon as the laptop has booted up because Kapersky is upgrading the virus definition file and is running a virus check on the files stored on the hard disk. When Kapersky has finished these tasks then you will see a drop in CPU useage.
NOTE as you install more programs and as your data files increase so will it take longer for Kapersky to carry out the virus scan.
Apr 18, 2012 | Sony Computers & Internet
my acer aspire 8930 9600m gt gpu keeps overheating what is the problem
Gaming (and graphics application) consumes more CPU/ Processor resources and due to the heavy processing the PC (CPU & GPU) heatup. Excessive heatup beyond usual is alarming and PC shuts down by itself when the processor/ GPU temperature exceeds the safe temperature limit. There are mainly two reasons for heatup.
Laptop heating issue generally occurs due to fan failure, which may damage the system, if not checked properly. Another most likely cause of overheating is the dust present inside the laptop, which clogs the fan and heatsink.
1. Make sure the fan is running. (if not it needs replacement)
2. Clean the fan and heat sink (thermal module). Click here for laptop disassembly instructions and refer to
Removing the System Fan/Thermal Module after removing the outer cover. Take out the fan and heat sink. clean them with the help of tooth brush and put it back. Also, repair manual can be searched online or downloaded for referrence.
The procedure is very simple, but if you are not comfortable with working inside electronics, I suggest that you should get you laptop checked by a professional for servicing (if required). I believe immediate action is required to prevent any damage to your machine and data.
Hope it Helps! Let me know if i could be of any further assistance.
CreativeTECH
Apr 16, 2011 | Acer Aspire AS5252V333 Notebook
overheat when i've played games
Gaming consumes more CPU/ Processor resources and due to the heavy processing the PC heats up. Excessive heatup beyond usual is alarming and PC shuts down by itself when the processor/ CPU temperature exceeds the safe temperature limit. There are mainly two reasons for heatup.
CreativeTECH
Apr 12, 2011 | HP Computers & Internet
I WAS HAVING PROBLEMS WITH OVER HEATING, NOW MY LAPTOP HAS CUT OUT AND WONT RE-START. WHEN YOU PRESS THE POWER BUTTON IT LIGHTS UP AND YOU CAN HEAR THE FAN OR SOMETHING BUT THE SCREEN STAYS BLANK. ALSO THE INTERNET BUTTON BESIDE THE POWER BUTTON STAYS AMBER.
When a laptop overheats the CPU will shutdown, this is known as thermal overload. The laptop will not boot up until the CPU has cooled down. If this problem in not fixed then the CPU will eventually fail.
This problem is usually caused by a faulty fan or the fan and heat sink is clogged with dust.
Replace the fan if it does not spin freely and or remove the dust clogging the fan and heat sink.
Oct 27, 2010 | Compaq Presario CQ60-220US PC Laptop
298 people viewed this tip
David Payne
David Payne
