Tip & How-To about GPS
How To Reset Your Magellan Triton GPS Unit
Factory Reset Procedure
  1. Using the stylus, tap "Main Menu" and select "View."
  2. Tap "Settings," and select "Restore Factory Settings." You will be given the option to confirm this action. Be sure that you want to reset to the settings that the GPS was built with. This action is irreversible
  3. Tap "Confirm," and the unit will begin to reset.
Developer Mode
  1. To enter Developer Mode, simultaneously press LIGHT+UP+PWR.
  2. To exit Developer Mode, simultaneously press ESC+ENTER+PWR.
GPS Logo
how to hard rest pantechp9060
from home scree press the menu kee and then tap settings. scroll and tap Privacy. tap factory data reset. tap reset phone. if security is enabled enter your unlock pin password or pattern. tap erase everything.
Alternative method.
1.power phone off
2.press and hold HOME, Volume down and power keys until an exclamation point is displayed next to an android on screen.
3. Press the Home key to view the Android system recovery options
4. press the volume down to scroll to Wipe data/factory reset. and then press the menu key to select.
5. press volume down to scroll to yes -- delete all user data and then press the menu key to select.
6. when data wipe complete is displayed select reboot system now.
Oct 28, 2013 | Computers & Internet
want to reset all settings
Follow the instruction given below:
Press "Home" > Settings >Privacy >Factory Data Reset
Read the message stating the types of data that will be deleted, then tap Reset Phone.
If you are certain that you would like to restore all factory settings, tap erase everything. Your phone will reset to the factory settings.
You can also use the method:
  1. Select Main Menu from the Home screen
  2. Tap Settings
  3. Scroll to and Select Phone Settings
  4. Scroll to and Select Reset Settings
  5. Tap Master Reset
  6. Tap Yes to confirm
  7. Enter the device's security code, then tap OK. NOTE: The default security code is 0000
Regards
Jul 07, 2011 | LG KS660 Cell Phone
Magellan 315 frozen
Occasionally, a unit will need to be reset. This can be due to software errors, firmware updates or simply at the command of technical support staff. A reset either will restart the unit, possibly clearing up any minor errors, or will restore the unit to the settings it was built with. There are three major Magellan units, which utilize different methods to perform this task.
Things You'll Need:
  • A thin object (such as a paper clip)
Tap "Settings," and select "Restore Factory Settings." You will be given the option to confirm this action. Be sure that you want to reset to the settings that the GPS was built with. This action is irreversible.
Maestro/Roadmate GPS Units
Locate the button marked "Reset" on the left, right or bottom of the unit.
Using a thin object, such as a paper clip, depress the button for two to three seconds. The unit should reset.
If the unit does not reset, immediately press the button again and hold it for up to 10 seconds.
Tips & Warnings
  • Do not attempt to perform a factory reset on the Roadmate or Maestro GPS units by holding down both the "Reset" and "Power" buttons. This will cause the GPS unit to format its own hard drive. Doing so will erase all data, including the GPS software, from the unit.
Jul 20, 2010 | Magellan GPS 315 GPS Receiver
When I power up my Triton 400 an Internal Error message window shows up and then the unit shuts down after a few seconds. It fails repeatedly. Is there something I can do to be able to use my GPS again ?
Hello :
First try new batteries . If that didn't work , then I recommend you to reset your Triton . Resetting can solve errors and faults that occurs in your device .
Try this for resetting :
1:Using the stylus, tap "Main Menu" and select "View."
2:Tap "Settings," and select "Restore Factory Settings." You will be given the option to confirm this action. Be sure that you want to reset to the settings that the GPS was built with. This action is irreversible.
3:Tap "Confirm," and the unit will begin to reset.
For that you need a thin object (such as a paper clip)
Don't use this method on other Magellan models .
PLEASE DON'T FORGET TO RATE !
Apr 14, 2010 | Magellan Triton 400 Handheld GPS Receiver
settings are in Spanish when I want it in English
  1. Remove all games from the DS.
  2. Turn the DS on by pressing the POWER button.
  3. Tap screen using the stylus when the "Touch the Touch Screen to continue" message appears.
  4. When the main menu appears, use the stylus and tap on the Settings Menu Panel at the bottom middle part of the screen.
  5. Tap the wrench icon (the leftmost icon).
  6. Tap the globe icon.
  7. Tap the box for the language you wish to choose.
  8. Tap the bottom-right box to confirm the selection (it says "Confirm" if the menu is in English).
  9. Wait for the the confirmation message to disappear, then tap "Go Back," then "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
Jan 10, 2008 | Nintendo DS Console
1,439 people viewed this tip
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
