Tip & How-To about Computers & Internet
Check links
If you want to see where the link takes you before clicking, position the mouse pointer on it and see the status bar, where the URL should appear. If you do not see the URL, click View, Status Bar.
Computers & Internet Logo
slow the mouse down on windeows 8
Although you don't specify which model, since you posted under the "Logitech Cordless Mouse" heading, I assume you have a Logitech mouse. In my experience, even modestly advanced (e.g., cordless, >2 buttons, etc.) Logitech mice don't always play well with mouse & keyboard settings tools found in Windows' Control Panel. Mr. Freeman's suggested adjustment to the generic Windows mouse management settings might be adequate for now. However, you're always better off using software specifically designed for your product.
The program you need is called SetPoint, and it's the key to getting full use out of your mouse or other Logitech device. All versions of the SetPoint software, and drivers for Logitech products, are available for free download at the Logitech support website. Here's the link:
http://support.logitech.com/software/setpoint
Logitech Support
Feb 22, 2015 | Logitech Cordless Mouse
mouse sensitivity is slow.i want more then more speed of mouse pointer,i already search but nothing...pleas SIR
These are the steps to change the mouse sensitivity
Click on the "Start" button in the lower left corner of your computer screen to open the Start menu so you can change the mouse sensitivity. Locate the control panel link on the right-hand column of the Start menu and click on the link.
Wait for the Control Panel manu to open and then locate the "Search Control Panel" bar at the top of the menu on the the right-hand side. Type in "mouse" (no quote marks) in the window and locate the mouse menu at the top, left side of the menu.
Locate the link that says "Change Button Settings" at the bottom of the mouse menu and click on the link. When the mouse properties window appears, locate the tabs at the top of the window and find the one that says "Pointer Options."
Click on the "Pointer Options" window tab and locate the heading that says "Motion." In the Motion section, find the slide ajustment bar that is labeled "Slow" on the left side and "Fast" on the right side of the bar.
Move the bar according to your desired speed and preferences, and click on the "Apply" button on the lower right-hand side of the window.
Click the "OK" button on the lower left-hand side of the window, which will take you back to the default window. Verify that the mouse sensitivity is according to your needs and readjust if necessary by repeating these steps.
Good luck
do rate the solution if got help
Dec 07, 2010 | HP P2360AA Keyboard/Mouse
Taskbar problem
drag it to the right then to bottom. first make sure its not "locked" by right clicking it.
Nov 29, 2008 | Computers & Internet
my gf has yahoo messenger, her status says she is offline! how does she change it? i am blind so can not help her withthis problemq
there should be a popdown menu that will show status.... just move the mouse pointer to the status she wants. also i belive (it's been awhile since i used yahoo) that if she right clicks on the icon for yahoo in the lower right hand corner of her task bar she will be able to change status from there
Robert
Sep 10, 2008 | Computers & Internet
153 people viewed this tip
David Payne
David Payne
