Tip & How-To about Computers & Internet
Hard drive space
It 's always a good idea to keep an eye on how much disk space you have available on your computer, especially when you install new programs. To check, right-click the C: drive in My Computer and go to properties. From there you can see how much space is available.
Computers & Internet Logo
Laptop C partition low disk space
Make sure your hard disk has enough space. Most often when the error massage comes it will tell you how much free space is required to install the game look keenly and know how much space is required then either move all media files mainly video files especially downloaded in the download folder to an alternative partition and only leave windows and installed program on Local Disk C. Other wise if your hard disk capacity is very small then am afraid that you will have to get a bigger hard disk.
Nov 27, 2014 | Computers & Internet
i cant install th windows live in my pc. i have fijustu intel pentium III with 256 RAM , 1.OGhz 64 graphic card maybe were is the problem ? is w.live mesenger for pentium III
First, the computer requires sufficient disk spaces to install a new program that would capturre to perform. Especially with multimedia programs, an amount of disk spaces are prior requirement on computer to allow download. 1.0gigaherz is only suffucient to power on and display what has been provided as devices default prorgams. Observe the computers innovativeness to ascertian the multimedia prospect. Usually prior computers least were designed to attain audio video media.
Feb 16, 2011 | Microsoft Windows Live Messanger
i had windows vesta but cant find same program for window 7. Can i take it from my old laptop to my new laptop ?
Programs are installed on the computer from package software's either as CDs or DVDs. Acquiring the entire program to be installed achieves several advantages. First, the program does not lack code complements. Second, the computer program that malfunctions would always have restore available. However, computers that are linked with networks are capable of sharing software codes. For example, once computers may request complementary codes from another to allow functionality to be achieved where one is outdated and the other recently innovative. In such an instance, the computer prescribes type of codes requested either as patch, codes, or update or upgrade. READ THE ESSAY BELOW FOR ADDITIONAL DETAILS
  1. If wanting to clone or transfer operating systems from another computer where one has a malfunction deficiency in programs requesting restoration from another with system compatibilities. Prior to the process, a compatibility check has to be performed on both devices, an estimate of the damage is determined on the computer requesting cloning to ascertain if any changes in software or hardware is required prior to the initial process commencement. Thereafter, the accessories that would be required like cables to link both devices are attained before the entire cloning starts.
Usually two computers are capable of sharing one operating system considering several conditions. First, both computers have to the have same operating system where one has experienced a malfunction requiring repairs from the other. Second, both computers prior to a clone require capacity checks. Usually the host computer would need available space to create back up before the cloning process begins should any malfunction compromise both devices integrity. Second, the receptacle computer requiring cloning depending on the conditions would require available disk space to contain the entire clone programs. Usually the cause of a computer to require restoration altogether of operating system requires evaluation since most computers only have enough space to contain an operating system with user interface fonts for productivity. Estimate the conditions on the damaged computer to ascertain if an erasure of disk spaces would be required to create spaces. Also, keep in mind that computers would not clone another system of its own if remnants of the master system are recognized as being present on the hard drive disks. The process of freeing the hard disk drives of spaces for cloning is called formatting achievable with some computers. However, the condition of formatting when not possible due to crashed or program compromises may simply require changing a new empty hard drive before the cloning would be made possible. Once the host computer is has the capacity to power an external device it nature either as available disk space to create backup required prior to cloning or usually a system checks to ascertain that the alternate computer has the capacity to receive every data. Alternately, the receptacle computer may have required changes of parts prior to cloning. A mentionable example includes hard disk drives to contain the new programs, also required to have enough space to create backup once the computer cloning is achieved. The next requirements check for cloning is ascertaining the appropriate cable connection that would be bridging the space gaps for data to be transferred. Usually an effective cable has the capacity to be recognized by both devices as measure prior to any cloning communications. Also, an efficient cable should have the most capacity to transmit data at quantities that does not cause malfunctions discussable. For example, the cables capacity may actually be able to transfer data only not capable of transferring every data size requiring transfer. Once the process is began with such a cable, some computers would transfer only what is achievable to the negligence of what is unachievable. However also, cable incapacity to transfer every data would would last several durations during the process o cloning. Simply said, the cables require compatibility to both computers, second an enormous capacity to outperform prevents any malfunction on the cable connections part during the cloning process.
  1. Alternately, a computers operating system is replaceable simply by acquiring the restoration programs at retail markets. However, the original computers restore operating systems program has to be acquired with details acquirable as computer type, year, models, and versions as guideline references in acquiring operating systems programs at retail. The reasons for such evaluation include acquiring a program that simply is adaptable to the malfunctioning computer. Alternately, a different operating systems program is acquirable on the retail market to replace the malfunctioning computers systems only with some conditions considered. First, the computer has sigficant parts that integrated with the prior operating system that may need alterations altogether to function with the newer but unique brand away from original brand specified. If choosing to acquire an alternate operating system from the original several additional alterations are required. First, the computer hard disk drive may need replacement either since most operating systems would not override an existing version unless every existing remnant programs were erased completely. Also, keep in mind that the older disk drive had spaces available to store programs from the older operating system that may have a unique requirement of spaces to perform. Acquiring another alternate operating system at retail may be compatible with the computer only the computer has least available spaces in store for separately engineered system programs. Simply said, each device has a set of requirements to perform with the remain ones on the computer being repaired. Where changing once original part that was connected to several other would require acquiring additionally the same remnant compliment from retail to achieve compatibility standards.
The operating system acquired on the retail market is usually in the form of a disk CD that is simply inserted into the computers drive medium from which restoration instructions are generated to achieve user experiences. For example, inserting an operating system disk CD in the drive of the computer should request either repairing the prior existing version on computer or simply replacing the entire system features. Usually, each acquired disk has instructions on the systems reconfiguration as would be termed. Alternative descriptions of the process are restorations, rebooting of installations of systems programs.
Important notes to be wearisome about when working with computers operating systems includes software and hardware compatibilities where a change may require alteration of the remaining, else a malfunction response would be likely. For example, the operating system is the command interface of the computer. Each operating system has functionalities where for example, the malfunctioning computer may have been designed for office productivity causing the manufacturer to install the compatible requisite program system for such an experience to be achievable. Especially on a computer that requires every functioning parts recognizable for communications to be achieved during user experiences, a change in one significant part that would achieve computer user expectation may not necessarily equate to every component parts usually functionality prior to replacement parts.
Consulting with a computer systems technician to achieve the experience would guarantee an experience of restoration functionalities were the computer user simple retrieves a device at functioning mode soon after repairs are completed. The significance of consulting with experts is several mentionable. First, professional hand tends to perform expectedly on devices. Second, experts are capable of the repairs without gimmicks experienced with alternate persons.
Jan 25, 2011 | Computers & Internet
Low disk space in Windows XP but I only had less program.
Is your computer's "automatic updates" on? With all the available updates the window's size come upto 12Gb. And if you haven't changed the Windows Page file area it would use your C:/  by default. Try changing the page file area. Go to Properties in My computer>Advanced TAB>Performance "click on settings">Advanced>Under "virtual memory" click change. And change the location of virtual memory to some other drive. And also do not forget to select "no paging file" for Drive which is low in memory. Try this it might work. And yes, as asked by Bonji5555, run file clean up once in a while. and defragment your disks. There are many free disk defragmentors available over the net, google and find one for yourself. Windows have a built in defragmenter but its really slow.
Feb 09, 2009 | Microsoft Windows XP Professional
136 people viewed this tip
David Payne
David Payne
