Tip & How-To about Computers & Internet
Server 2003 & client configuration
Some days before I have done a job on Windows Server 2003 Enterprise edition & Client XP. It is departmental food court. In the office room of the restaurant have a system which will be Server system and main domain. There was another 8 system in every department of food with printer for billing.I
Windows Server 2003 includes a mission critical Windows Server operating system, such as security, reliability, availability, and scalability.
You have to install DNS server for DC without DNS the client computers wouldn't know which one is DC.You can host DNS on a different server than DC.
Before Starting the DC installation process you need to make sure the following points
1)You have installed Basic windows server 2003 installation
2)Make sure you have assigned a static ip address to your server
Now start DC and DNS Setup process
Domain Controller Active Directory is a huge topic in itself. While DCPROMO is easy to run, planning of both the physical and the logical structure is the key to a trouble free active directory.
Domain controllers do not have to be your most powerful machines, however they must be reliable and always available to answer logon requests.
DNS (Domain Name System) Role
Once DNS is setup, it runs itself thanks to the new dynamic component hence DDNS. TCP/IP knowledge plus understanding of how DNS works is essential when troubleshooting connectivity problems.
DNS enables client machines to resolve servers IP addresses. Once the client finds the server, Active Directory uses LDAP to locate services like Kerberos, Global Catalog that clients request.
Print Server Role
In my experience there is a contrast between the software settings which are easy to configure and the hardware which constantly need for attention e.g. paper jam, 'out of toner'. Check list for print server:
Printer Priority
Network Printers
Client Configuration :- After Installation of Windows Xp give the IP Add on TCP/IP of IPV4.If you want to manually configure DNS server addresses, click Use the following DNS server addresses, and then type the preferred DNS server and alternate DNS server IP addresses in the Preferred DNS server and Alternate DNS server boxes. After all job try to ping each other. I'm trying this and it also pinging. Files and data also can be shared through it.
Computers & Internet Logo
I have an Ml 110 G5 Server, But i could not find the VGA driver for the Win Xp , kindly assist thanks Justin
Hi, I m really sorry to say that but you have a Server Product and its built to run Windows Server Series on it (or Linux / Novell Netware).
This is the list of compatible Server list
Microsoft Windows Server 2003 Microsoft Windows Server 2003 for 64-bit Extended Systems Microsoft Windows Server 2008 Essential Business Microsoft Windows Server 2008 Foundation Edition Microsoft Windows Server 2008 R2 Microsoft Windows Server 2008 Small Business Microsoft Windows Server 2008 W32 Microsoft Windows Server 2008 x64 Novell NetWare 6.5 Red Hat Enterprise Linux 4 (AMD64/EM64T) Red Hat Enterprise Linux 4 (x86) Red Hat Enterprise Linux 5 Server (x86) Red Hat Enterprise Linux 5 Server (x86-64) SUSE Linux Enterprise Server 10 (AMD64/EM64T) SUSE Linux Enterprise Server 10 (x86) SUSE Linux Enterprise Server 9 (AMD64/EM64T) SUSE Linux Enterprise Server 9 (x86)
Here is the link for Drivers
Try to use the Driver for Windows 2003.
It has a Matrox VGA as I know. If you know which Matrox series you have, then Browse here for the Drives: Matrox Graphics Support. Make sure that you choose the Exact Driver software which suites the System.
Note: Not every product has the Driver Software for Windows XP.
Please rate the answer! Thanks for contacting Fixya!
Jun 19, 2010 | HP Compaq ProLiant ML110 G4 Server
We Are Using Windows 2003 Server,But We Are Not Able To Access Server From Win XP & Win 98 Clients & Also We Are Not Able To Access Clients From Win 2003 Server. Please Help.
You must be on same domain/workgroup to see it and the computers should have an account on the server.
If not you MUST have a user account you are using on the server.
You can try to connect using the IP address of the server as such:
Go to start.run then type \\Serverip\c$ it should then ask for credentials
If not then your server is not on the network properly and you should contact a consultant in your area to configure the server
Mar 16, 2010 | Microsoft Windows Server 2003 Enterprise...
I am trying to download PCAnywhere 12.0 to windows 7 and it tells me they are not compatible
That is correct Symantec list supported operating systems and Windows 7 is not compatible..
System RequirementsWindows 2000 Professional/Server/Advanced Server
Windows XP Home/Professional (32-bit and 64-bit)
Windows 2003 Server Standard/Enterprise (32-bit and 64-bit)
Windows Vista Ultimate/Business/Enterprise/Home Premium/Home Basic (32-bit and 64-bit)
Windows 2008 Server
Internet Explorer 6.0 or later
Regards
Nov 10, 2009 | Symantec pcAnywhere 12.0 Host & Remote...
i'm trying to log into local administrator in windows server 2003 enterprise edition, but it will doesn't support me to log on into system...
If it is a problem with a locked out account or incorrect password, & you need to unloack the account or reset the password, then you can use the Offline NT Password & Registry editor.
You can download it at the following link: http://home.eunet.no/pnordahl/ntpasswd/
This utility will enable you to reset the password of any user that has a valid (local) account on your Windows NT/2k/XP/Vista etc system.
The link above includes some directions on how to use this utility.
Nov 02, 2009 | Microsoft Windows Server 2003 Enterprise...
169 people viewed this tip
David Payne
David Payne
